how vital is locker
Discussion in 'Off-Roading & Trails' started by 1546, Jul 5, 2013.
  1. Jul 5, 2013 at 8:36 PM
    1546 [OP] New Member
    about to get an 2007 DC TRD sport. My only hold up is the no locker thing. lLease advise. The only place I go that might be a problem is a gravel boat ramp. I have never seen anybody unable to get up it but I don't want to be the first. Is LSD enough in most situations or should I hold out for trd off road so I get the locker. If it matters its an 07 with 75 k miles for $20K
  2. Jul 5, 2013 at 8:41 PM
    TCprerunner
    TCprerunner Well-Known Member
    If it becomes a problem buy a after market locker will work better anyways but you should be fine on a gravel boat ramp my truck is not locked and only 2 wheel drive and only time I have gotten stuck is on a really steep rock hill with loose slate
  3. Jul 5, 2013 at 8:44 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
  4. Jul 5, 2013 at 10:21 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    For a boat ramp..LSD will be fine.
    Unless your going t d trails and crawling. Don't worry about it.
  5. Jul 6, 2013 at 12:53 PM
    Techy
    Techy Well-Known Member
    Montrose, CO
    06 trd off road dbl cab
    I think you will be. Never had an issue on a boat ramp with just normal 4wd on the rough ones.
  6. Jul 6, 2013 at 12:58 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yep. Overkill for your described usage. Of course, if you *want* the locker - well, that's another matter entirely. <evil>
  7. Jul 6, 2013 at 1:08 PM
    TCprerunner
    I want one.. But going cheap route and getting a lunch box and will deal with tire wear
  8. Jul 8, 2013 at 10:42 PM
    logan1992
    logan1992 Well-Known Member
    logan
    gunnison colorado
    2004 tacoma trd
    ome Dakars in rear and ome 882's in front. 255 85 16's maxxis bighorns
    if you don't wheel hard you don't need it. the real situation where a locker comes in handy is flexy stuff where you pull a wheel off the ground. if you wheel hard a locker is more important than lift and tires imo but if not than don't sweat it.
  9. Jul 12, 2013 at 10:23 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    West Coast
    03 Access Cab TRD 4X4 V6
    19 Gallon Auxillary Fuel Tank Beeper Dampened 12V's always hot LED Reverse Lights Snug Top Hi Liner Camper shell Sleeping Platform w/ drawers Deck Plate Mod Kuat Core Hitch Rack OME All Around w/ AAL Built in 800 Watt Inverter Gray Wire Mod 2Lo Mod 235 85 R16 General Grabber AT3's Hella 500 FF's Relayed into High Beams 42" LED Light Bar Relayed into High Beams Reverse Camera Paranoid Fabrications Switch Panel Under Hood LED Light Sway Bar Delete 1996 Yamaha YZF 600 Daily Driver
    I've used my locker several times. But like Logan1992 said it's only been in flexy situations where one wheel is off the ground or where the soil is super loose. It doesn't help I'm using General Grabber AW tires either. They kinda suck for off roading.
  10. Jul 12, 2013 at 12:05 PM
    FireSarge
    FireSarge Member
    Aaron
    El Paso, TX
    2013 Super White TRD Off Road
    Flowmaster 40 Series, Swing Case Truck Box, Tail gate theft mod, Undercover Flex, Hi Lift add on, Daystar Lift, pigtail antenna, Plasti Dipped Grill and wheels, Red Pepper colored emblems, weather tech window visors, LED's on all inside lights
    IMG_3414.jpg:D
  11. Jul 12, 2013 at 2:10 PM
    Fivespeed
    Fivespeed Well-Known Member
    Tualatin, Oregon
    '12 TRD Offroad w/ Entune
    That's how you have fun in a 2013. And I thought I was crazy in my 2012 :cool:
  12. Jul 12, 2013 at 3:06 PM
    spyduh
    spyduh Member
    99 Taco XtraCab TRD 5spd
    OME Lift, Wheelers Rock Crawlers Type B on BFG 32s, Grey wire mod
    if all you're doing is boat ramp then you'll not need a locker.
    If your wheeling or trailing and in areas that you'll get stuck, buy a TRD with elocker.
    Or buy the truck your're looking at and drive it. if you decide in the future to do wheeling/trailing add an ARB front and rear locker to the truck. Much better than the elocker imho. But LSD is good enough if you dont plan to do crazy stuff out in the middle of no where alone.
  13. Jul 12, 2013 at 3:15 PM
    Khaos
    Khaos Big Member
    Bryant
    Tallahassee FL
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Locker isn't much a help on a boat ramp. If it's bad, you really should get a 4x4. Go youtube boatlaunch fails if you need convincing.
    My locker has saved my ass many times. My Prerunner definitely will go places other 2wds will not. I would not have made it up that in my sig without my locker, or without my tires. An unlocked 2WD would have been screwed. That said, when I'm off roading, I'll have difficulty on places that my 4x4 companions will walk right through. A locker is helpful, but nothing replaces 4x4.
  14. Jul 12, 2013 at 8:54 PM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    i could do all that open/open :stirthepot:
  15. Jul 15, 2013 at 11:06 AM
    bwanamukubwa
    bwanamukubwa Well-Known Member
    Tennessee
    Does the "yellow wire mod" perform the same way as the prado in part 2 where it "bites" and "unbites" or is it a smoother operation?
  16. Jul 23, 2013 at 5:30 AM
    bwanamukubwa
    Tennessee
    Can anyone chime in on this please?
  17. Jul 23, 2013 at 7:41 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    You will be fine. I have run piles of black/double black diamond trails, including Gold Mountain, John Bull, etc in Big Bear with the stock mechanical LSD, a little E-brake love and it locks right up. Its more about line selection and driving than anything.
  18. Jul 23, 2013 at 7:43 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Get 4WD
  19. Jul 23, 2013 at 8:55 AM
    bwanamukubwa
    Tennessee
    I have a 4wd TRD sport, just trying to justify doing the mod. Maybe i'll just learn how to do it in case i'm stuck as a last resort since i'm still learning about the benefits of doing it.
  20. Jul 26, 2013 at 9:26 PM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd & Silver 06 SR5 4Runner
    OME 885 springs on 90000 shocks, sway bar removed and 1.5" AAL
    yup
