How well does the Adaptive Cruise Control work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gdgraph, Nov 26, 2020.
  1. Nov 26, 2020 at 1:34 PM
    gdgraph
    gdgraph [OP] Well-Known Member
    Northern Virginia
    2020 TRD Pro
    How well does the adaptive cruise control work on the Tacoma? Can you commute on the highway in heavy traffic with it or will is deactivate in stop/go traffic?
    Does it leave too big of a gap in front of you where people can come over in your lane making it slam on the breaks?
    I used it one on a rental but the area I was in was much more rural and not as may cars as where I live.
    GSDLVR123 likes this.
  2. Nov 26, 2020 at 1:36 PM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    It leaves a big gap.
    Chew, Bus007G and 71tattooguy like this.
  3. Nov 26, 2020 at 1:37 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Its nice on the highway as it will slow down and speed up to the speed you set it at. You can also adjust the distance between you and the vehicle in front. I am not sure I would trust it in heavy traffic.
  4. Nov 26, 2020 at 1:42 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    It works best for highway. While it does have 3 settings for the gap, it does not have the ability to brake, only coast. So no on the stop and go traffic. Also, it can be very aggressive on the throttle - if someone slow changes lanes it will go near full throttle and drop gears to reach the set speed again.
    Edit: It can use the brakes, to some extent.
    PFB and jimilee like this.
  5. Nov 26, 2020 at 1:46 PM
    Mozart
    Mozart Well-Known Member
    Cortland NY
    2018 ACLB SR5 4x4 V6
    32” Tires, BPF Front Recovery
    On the 2018s, it shuts off below 25mph. It’s slow to respond to people that brake suddenly, even at the full follow distance setting. If you don’t do your own braking you’ll rear-end someone. So it’s only good for maintaining a gap at highway speed and you still need to watch for people braking suddenly. TSS 1.0.
    I still enjoy using it and having it, but my wife’s Volvo goes down to standstill and reacts almost immediately.
    ian rogers likes this.
  6. Nov 26, 2020 at 1:49 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Don't use any cruise control in heavy traffic.
  7. Nov 26, 2020 at 1:51 PM
    gdgraph
    Northern Virginia
    2020 TRD Pro
    Oh, I didn't realize that it didn't break at all especially since part of the safety stuff it has the emergency breaking. So I probably wouldn't be able to use it much at all since a normal day commuting is so congested and cars slow down and speed up constantly.
  8. Nov 26, 2020 at 1:56 PM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    It works great. A month ago I drove from Tennessee to Minnesota in two day - I would set the cruise control and basically just let the truck control things. All I did was steer for hours at a time. If I didn't have it I would miss it, and I generally hate electrical conveniences.
  9. Nov 26, 2020 at 1:57 PM
    Blackbeard83
    Blackbeard83 Well-Known Member
    Sam
    Massachusetts
    2020 TRD Sport 4x4 ACLB MBM MT
    currently stock
    If someone gets in front of me and is going slower than me it will brake.
  10. Nov 26, 2020 at 1:58 PM
    VeeSix
    Tennessee, USA
    2011 Tacoma 4x4
    It will definitely brake. Definitely.
  11. Nov 26, 2020 at 2:02 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    It lost definitely slows with aggression if someone cuts in front. The hard throttle when someone changes lanes is jarring a bit. I’ve come to like it now that I understand it. I hated it on my wife’s Highlander.
    BSFord and davidstacoma like this.
  12. Nov 26, 2020 at 2:03 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    That is self driving territory. The collision avoidance is a totally independent system.
    There is open pilot self driving add-on compatible with some Toyota's, only with electric power steering though.
  13. Nov 26, 2020 at 2:03 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    It's more sensitive than a teen age girl that got dumped on prom night.
    Useless if it starts to snow or anything gets on the eye.
    Blackbeard83 and davidstacoma like this.
  14. Nov 26, 2020 at 2:06 PM
    Luckypierre
    Luckypierre Active Member
    Sorry but this is false, a Gen 3 with TSS 100% brakes on its own with DRCC engaged.
    From Toyota:
    “If a driver is traveling slower than you, or within your preset range, DRCC will automatically slow your vehicle down without deactivating cruise control. If DRCC determines you need to slow down more, an audio and visual alert notifies you and brakes are applied. ”
    Toyota Safety Sense has two levels of adaptive cruise control:
    • Dynamic Radar Cruise Control from 25-110 MPH (what the Tacoma has)
    • Full-Speed Dynamic Radar Cruise Control from 0-110 MPH (not available on Tacoma)
    Read all about it here: https://www.toyota.com/safety-sense/discover/feature/drcc
    I use it and like it but am always prepared to retake control especially when the traffic gets heavier.
  15. Nov 26, 2020 at 2:06 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I like it. My step sister does 95% of her driving with adaptive cruise control on. She has a 2018 TRD Off-Road
    davidstacoma likes this.
  16. Nov 26, 2020 at 2:11 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Is there a way to turn it off and run without adaptive?
  17. Nov 26, 2020 at 2:12 PM
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    Yep, you're right. I just looked myself. I was thinking of a different vehicle I guess. It does say in the manual it will output a warning if it cannot slow enough, so I assume it has a limit of how much brake it can use.
  18. Nov 26, 2020 at 2:13 PM
    Walter Mitty
    Walter Mitty Member
    I use my Dynamic Cruise Control everywhere I drive. I have a 2019 OR with all the bells and whistles. Mine will maintain speeds up and down hills even shifting into lower gears and using the brakes if I start going too fast down hill. I kind of wish I could toggle that feature.
    I use mine around town in traffic and as someone else said you can adjust the distance to the car in front of you between 1 and 3 car lengths. My truck will apply the brakes if needed to slow down. Below about 28 MPH it beeps and shuts off. The cruise cannot be turned on if you are in "S" mode below 4th gear which is something else I would change if I could.
    The system in my truck will sound an alarm and spike the brakes if someone cuts in front of me or I'm closing too fast on another vehicle for the parameters of the system. An example would be someone ahead of me in traffic has a signal on and is turning out of my path. The truck will alarm and spike the brakes way before I would and it can be annoying in that regard. It's obvious that while I can see a car turning out of my path that will be well clear of the road by the time I get there, the computer apparently treats it as an object that will remain in my path.
    So we had a section of highway heading into the big city that was torn up with construction for a couple of years. Speeds would vary between 35 to 65 MPH due to traffic and lane shifting etc. I got to where I didn't want to drive my wife's car because you couldn't use cruise without constantly fiddling with it. In my Tacoma I just set the top speed and spacing and let the truck speed up and slow down with traffic.
    If you choose, you can press and hold the cruise control button for 1.5+ seconds and it reverts to more traditional Cruise control operation.
  19. Nov 26, 2020 at 2:16 PM
    Truky!
    Truky! Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    Compared to the adaptive cruise in my previous car, this system is awesome, it accelerates strong when the vehicle in front of me speeds up or leaves my lane.
    In the Kia I had it was embarrassing how slow it accelerated.
    Secondchildhood likes this.
  20. Nov 26, 2020 at 2:41 PM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I despise it. I also drive excessively fast. I guess if you drive like a little ol' lady, it is probably great. Because I am passing everything, the sudden slow down has almost resulted in a crash because I see the car in front an plan to get around, but before I change lanes, it cuts the power and puts me at risk of taking out the car to my left due to the loss of momentum.
