How well does the Adaptive Cruise Control work?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gdgraph, Nov 26, 2020.
  1. Nov 29, 2020 at 3:56 AM
    #101
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    It works better than the auto-dimming headlight feature.
    GSDLVR123, Smokinnuts, HP11 and 5 others like this.
  2. Nov 29, 2020 at 6:42 AM
    #102
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    Yes definitely. This is in the owners manual, but a quick press of the button results in DRCC, but holding the button in for a few seconds, will then enable classic cruise control, and yes, you notice the different symbols in the dash, signifying which one is on.
    Tullie D likes this.
  3. Nov 29, 2020 at 6:45 AM
    #103
    oogielaflick
    Keith
    Yes, I heard about this TSB, but I think it completely disables the entire TSS system and not just DRCC. I actually like the PCS part of it, but just hate the DRCC module. And I DO have the aftermarket TRD Pro grill, and the PCS system has worked fine since turning over 6000 miles. I now have just over 32,000 miles.
    ktbell444[QUOTED] likes this.
  4. Nov 29, 2020 at 7:19 AM
    #104
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    The adaptive cruise is excellent and I use it a lot. It helps me to dislike the transmission all the more since I'm not pushing the gas peddle as much.
    For two lane roads I leave it set at 3 (the default), and usually 1 on the highway when other vehicles are around me. Unfortunately my 2018 4Runner doesn't have it.
  5. Nov 29, 2020 at 8:13 AM
    #105
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Yeah, it does have its quirks. But it is much better than earlier systems. The earlier systems would slam on the brakes when another car merged into your lane just in front of you. Toyota's is at least smart enough to know not to do that. My biggest complaint is that it will stay locked on to a vehicle that moved over one lane, into a turn lane for instance, and will start applying your brakes as the other vehicle slows down. But I've learned to either press on the gas or turn off CC temporarily to avoid that.
    davidstacoma likes this.
  6. Nov 30, 2020 at 5:00 AM
    #106
    RatAssassin
    RatAssassin Well-Known Member
    I like it.
    I would never use it in traffic which usually isn't a problem here.
    I use the largest gap setting because I like that bubble of space around me.
    Like others, I'll momentarily turn it off to get around slower vehicles. Its a little harsh on dropping gears to get back up to speed as fast as possible.
    As far as the system goes, I feel it works well.
    BMH and davidstacoma like this.
  7. Nov 30, 2020 at 10:28 AM
    #107
    CementNKY
    CementNKY Active Member
    2018 TRD OR DCSB
    2.25” Lift, 5100s and 887 Coils, 265/75R16
    I love it and use it a lot on the highway. One thing my fiance's Subaru does that I wish Toyota would adopt is allow it to speed up when you signal for a lane change. For instance, we will be following someone in her Subaru with speed set at 70mph, car ahead is only doing 65mph so it slows down. However, as soon as I turn on the turn signal it begins to accelerate before I move into the next travel lane. Super nice on a 12hr drive to Florida.
    grogie and davidstacoma like this.
  8. Nov 30, 2020 at 11:06 AM
    #108
    Pnciv66
    Pnciv66 Well-Known Member
    Louisiana
    The only time I use the cc is on interstate it does work as described slows the truck down when traffic is moving slower then the set speed. It has 3 settings but I find the lowest setting starts slowing down too soon.
    For me personally I don’t like the adaptive function and turn it off whenever I use cc. I think I just prefer old school cruise control
  9. Nov 30, 2020 at 11:27 AM
    #109
    FarPost79
    FarPost79 Member
    Seth
    Peoria
    2019 Magnetic Gray Metallic TRD Offroad
    When using CC and the RPM's are reving high you can tap the gas pedal and it will switch the gears and drop your RPM's while maintaing your set CC speed.
  10. Nov 30, 2020 at 3:41 PM
    #110
    evdog
    evdog Well-Known Member
    San Diego
    2019 DCLB TRD OR
    That's been my experience ^^. Not a fan. It'll accelerate hard to get up to speed or while climbing a hill, then when it gets in range sensing a slower vehicle it will slam on the brakes. It would be a much better system if it would ease off the throttle to slow rather than brake hard.
    I had a Sienna minivan rental on vacation a couple years back which had a much better system. We'd be cruising on the interstate with cruise set at 75, and look down and realize we were going 65. WTH? We'd gotten behind a slower vehicle and not even noticed the minivan slowing to match its speed. That was annoying in itself but not nearly as annoying as the hard braking and accelerating.
    Thanks to those who pointed out you can turn the adaptive cruise off. I'll definitely be trying that.
  11. Nov 30, 2020 at 4:21 PM
    #111
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    That's about my opinion as well. I have an MT so no complaints about the auto trans (I traded my 2017 AT for a 2018 MT Pro). I use in on long trips on the freeway only, but often switch to the standard CC often when the traffic gets thick.
  12. Dec 20, 2020 at 5:21 PM
    #112
    el_burro
    el_burro Well-Known Member
    2018 TRD OR DCLB
    Just used this for the first time on a 14 hour drive. I absolutely love the adaptive cruise. I was amazed at how well this works on my 2018. I did turn it off in stop and go traffic, but at highway cruising speeds this works amazingly well. For me this is game changing on long highway drives.
  13. Dec 20, 2020 at 5:30 PM
    #113
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Yep, I made a 600 mile mostly interstate round trip last month and the adaptive cruise is a game changer one you learn when to use it and to momentarily disable it when passing a slower car to avoid revving high, makes for a much more relaxed drive!
    Blackbeard83 and Secondchildhood like this.
  14. Dec 20, 2020 at 8:58 PM
    #114
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Frankly, I would rather my new Tacoma didn't have cruise control. It's just a waste as far as I'm concerned. I've never used it when available, and I would never use it.
    At my age (I'm 75), staying alert while driving is very important. One way to stay alert is to maximize driver input. That's why I'm a fan of the manual transmission, and not a fan of cruise control.
    RosettaBanana and davidstacoma like this.
  15. Dec 21, 2020 at 6:19 AM
    #115
    grogie
    Although I highly prefer cruise control for long trips, you have a point that these driving aids give us the reason to pay less attention to driving.
  16. Dec 21, 2020 at 7:52 PM
    #116
    Taco Pat
    Taco Pat Well-Known Member
    Patrick
    SoCal
    2018 Tacoma TRD Off Road
    Overall I like it and use it for highway driving with moderate traffic.
    Similar to what other people have said, it can accelerate hard when people change out of your lane and will also brake hard when someone cuts in front.
    I like the ability to change the distance between cars.
    The biggest problem I have is when it slows down for cars in front of me gradually and I don’t realize I’m going 5-10mph under the limit for a while..
    Update: I just finished another 2,000 mile trip and as others mentioned, when a car changes out of your lane it accelerates hard and tends to stay in 4th gear for way longer than if you were accelerating yourself. It’s a little annoying
    Blackbeard83, grogie and davidstacoma like this.
  17. Jan 18, 2021 at 4:56 AM
    #117
    AWD OWNZ U
    AWD OWNZ U Well-Known Member
    SoCal
    2021 White Tacoma TRD Pro
    Disagree. Adaptive cruise is much less fatiguing on long drives. You’re safer being less fatigued and able to react than you are getting tired from constant reactions and adjustments to speed.
    Secondchildhood and Tacoma559 like this.
  18. Jan 18, 2021 at 6:00 AM
    #118
    Texasdeere
    Texasdeere Member
    Southeast Texas
    2021 DCSB SPORT
    I drove a new Toyota Corolla rental with the adaptive cruise about 3 to 4 years ago. I loved it! It was very smooth with no braking or hard acceleration.
    I hate the Adaptive CC on my new Tacoma. Way too aggressive!
  19. Jan 18, 2021 at 3:25 PM
    #119
    Magna111
    Magna111 Member
    Probably, but the smallest gap at 80mph is big enough for a semi to feel comfortable changing lanes into ...
  20. Jan 18, 2021 at 3:39 PM
    #120
    Magna111
    Magna111 Member
    when it hangs in a gear too long, which seems like just about always, if you blip the throttle (and you’re at speed and on level road) it will drop to 6th. It will stay in 4th at like 3500-4000rpm for 15-20 seconds while maintaining the set speed before it eventually shifts, or blip the throttle as soon as you hit your speed and it will instantly drop from 3500 to 2100.
    I can easily get 2mpg better driving myself than I do with ACC, but it is nice to set it and not have to worry about creeping too fast, and it maintaining distance behind the car ahead of you.
    Blackbeard83 likes this.
