How well should clutch fluid reservoir lid seal seal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5efvz, Sep 19, 2022.
  1. Sep 19, 2022 at 6:50 PM
    5efvz
    5efvz [OP] Well-Known Member
    It definitely doesn't have near an airtight seal as the brake fluid reservoir. It's very floppy and comes off with very little prying.
    Is this normal?
  2. Sep 19, 2022 at 7:41 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    Good enough to not let fluid out.
    skeezix and 5efvz[OP] like this.
  3. Sep 19, 2022 at 9:37 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Will a Good hard impact jar the cover off the clutch Master cylinder??
    As long as the fluid does not push the lid off.
    When was the clutch Master Cylinder changed last?
    It should be as tight as the Brake Master Cylinder.
    5efvz[QUOTED][OP] and Key-Rei like this.
  4. Sep 19, 2022 at 9:46 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    On my first gen it wasn't loose but I wouldn't say that it fit particularly snugly either more so that the cap itself was softer than the brake fluid reservoir cap it could very easily be pried off with two fingers where the brake fluid required twice the effort though also wasn't difficult either.
    I never had any issues with it leaking fluid or popping off while wheeling though.
    5efvz[OP] and Bivouac like this.
  5. Sep 20, 2022 at 7:05 AM
    5efvz
    Unknown. Truck had 3 previous owners. I didn't know these were wear items.
  6. Sep 20, 2022 at 9:16 AM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I needs to keep the air/moisture out so it should be tight enough to seal.
    5efvz[OP] likes this.
