How/When to use 4H
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tranceporter, Mar 14, 2012.
  1. Mar 14, 2012 at 6:45 AM
    tranceporter
    tranceporter [OP] Well-Known Member
    Rishi
    Atlanta, GA
    4x4, DCSB, Off Road, V6 Tow
    Hi All, Sorry this may be a noob question. I searched the forum, read the owners manual and am a little confused due to the conflicting information I got so I figured I'll just ask. Keep in mind this is my first truck/4x4/4wd vehicle ever so I'm very new to all of this.
    I was reading through the owners manual about the 4x4 system, the locking diff's 4H, 4L, climb/descent assist etc etc and 1 thing was clear, most of the features are low speed off road types only. Same as what I discovered reading on the forum. The part that confused me and maybe I'm not understanding whats said properly is using the 4X4 (4H) function.
    Per the owners manual I should drive the truck for about 10 miles in 4H to keep the front differential/drive mechanism lubricated and working. I've read mixed things on here. Can someone clear things up for me in regards to that. I've only done city driving with the truck thus far, commute to work and back.
    Any advice would be greatly appreciated. Thanks!!
  2. Mar 14, 2012 at 6:46 AM
    YNOT2K
    YNOT2K Member
    Jeff
    Seattle, WA
    2005 Access TRD Offroad
  3. Mar 14, 2012 at 6:49 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    don’t ever drive on dry roads. also i think think it has to be done for 10 miles a month. i have gone a month or 2 with out using it even for 10 feet. works fine.
  4. Mar 14, 2012 at 6:52 AM
    feldman28
    feldman28 Well-Known Member
    chris
    batavia
    09 sr5 stick
    I use it if in the yard and its soft don't want to spin. Or while wheeling
  5. Mar 14, 2012 at 6:53 AM
    tranceporter
    Rishi
    Atlanta, GA
    hahaha I was expecting this. I've seen so many people get reamed for asking this question.
    Blonde moment.... When you say dry you mean normal roads or is rain ok?
    It really bothers me that the owners manual is this ambiguous about how/when to use it.
  6. Mar 14, 2012 at 7:06 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Its a good question, if you don't know, its better to ask than to screw something up.
    By dry, they mean any road that your wheels can't slip. Rain, there is not enough slip to keep you from binding, so I still wouldn't use it in rain. Its ok to do the 10 mins on "dry" or asphalt roads as long as you are not making any turns. If you have ever had 4wd on and tried to make a turn, you will notice a hesitation, and its hard to move, specially a hard turn, that is binding. You don't won't binding, because that is potential damage.
    And as far as when you use 4lo, well it all depends on the situation, people use it off road, for that lower gear and more power to pull the truck up and over obsticles, also say for maybe a pulling/towing situation, you may need the extra power to pull.
    Main thing is, you only want to use 4hi/4lo as long as you are on a surface that you wheels can slip, if not, you have to much traction and you don't need it, and if left on it can cause damage. Rare, but it can.
    burntcremebrulee likes this.
  7. Mar 14, 2012 at 7:31 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Did someone ask what happens when you flip the switch to 4WD?
    nm ..
    I got all excited for a moment.
  8. Mar 14, 2012 at 7:35 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL, you should repost that here anyway, just because it was so epic!
  9. Mar 14, 2012 at 7:39 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Who told you that :confused: I know for a fact my drive line does not move wile in 2wd. Your front diff is always turning (unless you manual hubs) but I'm pretty sure the 2nd Gen front drive lines do not move in 2wd.
  10. Mar 14, 2012 at 7:56 AM
    Thighmaster
    Thighmaster Well-Known Member
    Ward, Colorado
    2012 Red TRD Off-Road
    June 2016 OME Dakars + 3" ToyTec Boss Lift
    My 2£ worth: I flip on the 4WD as soon as I hit the dirt road to our place to get the 10 miles/month lube job. Hadn't thought to add 4lo on occasion.
  11. Mar 14, 2012 at 7:59 AM
    tranceporter
    Rishi
    Atlanta, GA
    So at a high level to summarize, user 4H/L only on pavement where traction is sketchy. Only drive straight with it, no big turns. All other times use 2H
    This is clearly too complicated for the owners manual lol... Thanks for helping out a noob and being gentle about it. Much appreciated.
  12. Mar 14, 2012 at 8:06 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    :thumbsup:
    In Alaska we keep vehicles in 4H for October-March normally, so there is some dry pavement turning involved, never had anything break because of it. Definitely do not engage 4H or 4L while turning though.
  13. Mar 14, 2012 at 8:14 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not very often you will use 4L on a road , but you seem to have the general idea figured out OP
  14. Mar 14, 2012 at 8:18 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    Why are you being helpful? Are you sick?
  15. Mar 14, 2012 at 8:24 AM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    Lol. But OP you've got the idea. Although being in Atlanta I don't know if you will be able to find a long stretch of road and not have to turn. Never know when somebody is gonna pull right out in front of you.
  16. Mar 14, 2012 at 8:29 AM
    scocar
    scocar hypotenoper
    OP, tha main idea I haven't seen anyone quite hit on here yet (although there is plenty of good advice) is that 4wd will cause gear binding if you turn on a surface that does not allow the wheels to slip and turn at different speeds (and therefore not bind up). So, dirt roads are good for this. Rain, however, does not qaulify, because your tires are designed to maintian traction on wet paved surface. Otherwise, finding straight stretches of pavement in areas where there are little to no chance of having to perfrom sudden evasive maneuvers (other than stopping in a straight line) are an option.
    4H is usually suited to slippery snowy highway or higher speed dirt or muddy or sandy roads where additional traction and control is needed, but conditions still allow you to go fairly quickly.
  17. Mar 14, 2012 at 8:36 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I did. :D:p
  18. Mar 14, 2012 at 9:00 AM
    tranceporter
    Rishi
    Atlanta, GA
    I actually bought the truck to do a road trip to Alaska. Otherwise being in Atlanta I could have done with a 2WD truck.
    This is so true. I should just throw on 4H and start rampaging through all my neighbors back yards lol
    Thankyou for the 2nd paragraph. Thats what I was thinking as well.
  19. Mar 14, 2012 at 11:49 AM
    scocar
    scocar hypotenoper
    I knew that would happen. :homer:
  20. Mar 15, 2012 at 1:14 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Nice! :D :cool: :D
