How will 31's look with a 6" inch lift until I get 33's?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LUCKxxJesusJNJ, Jan 10, 2018.
31 inch tires with 6inch lift
  1. It will look fine still
    5.4%
  2. It will look terrible don’t do it
    59.5%
  3. It will be tolerable but deffinetly get bigger tires ASAP
    35.1%
  1. Jan 10, 2018 at 11:59 AM
    LUCKxxJesusJNJ
    LUCKxxJesusJNJ [OP] Member
    2016 quicksand taco sport
    5 percent window tint led light bar in the grill
    I’m about to get a bds 6 inch lift but I don’t have the finances to get bigger tires my current tires are 31 inch tires I’m going to get 33s for the lift but how bad will it look with the 31s until I get the finances
  2. Jan 10, 2018 at 12:05 PM
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    I am not sure that your Sport wheels will even fit after the lift. I believe that the Tie Rod will hit the on the 17" stock Sport wheel. I am almost positive that with the 6" BDS kit that you will need to go up to an 18" or 20" wheel.
    You may be able to get away with it with some wheel spacers on your stock wheels, but not completely positive on that
  3. Jan 10, 2018 at 12:38 PM
    LUCKxxJesusJNJ
    I currently have a 3 inch lift I’m not sure what size rims tho but the tires rub if I cut the wheel all the way which is part of the reason I wanna lift it higher I bought it this way but I’m not sure if the rims are the same size as the stock I done think they are
  4. Jan 10, 2018 at 12:42 PM
    LUCKxxJesusJNJ
    This is my current size
  5. Jan 10, 2018 at 12:44 PM
    scottsglock29
    Scott
    Wisconsin
    Those are definitely aftermarket wheels. Where is the tire rubbing?
  6. Jan 10, 2018 at 12:49 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Cab mount chop if you want to keep 3” lift.
    scottsglock29 likes this.
  7. Jan 10, 2018 at 1:10 PM
    NV_Spencer
    NV_Spencer Well-Known Member
    2020 CREWMAX / 2017 OR DCSB
  8. Jan 10, 2018 at 1:20 PM
    scottsglock29
    Scott
    Wisconsin
    You can absolutely go with the 6" BDS (an excellent kit IMO), but you will definitely need the proper backspacing for the wheel (4.5). With an 18 x 9 wheel that is about a -12 offset. With the correct backspacing that SHOULD eliminate rubbing. Although every truck is different and some trimming may be required.
  9. Jan 10, 2018 at 3:32 PM
    LUCKxxJesusJNJ
    I’m lifting cause i want it higher and It’s rubbing in the back and I can’t fit the mudflaps I bought because of it ethier and when I go over a curb it bottoms out so I wanna lift to avoid that
  10. Jan 10, 2018 at 3:59 PM
    MCDavis
    MCDavis Taco life is over. Full time 4wd for the win.
    RIC, VA
    2017 TRD Sport 4wd (SOLD) - Currently in a 2016 GX460
    BDS recommends at least a 18” wheel with 4.5” backspacing.
    So what are the specs on YOUR current wheels?
    And yes, 31s will look a little goofy with a 6” lift. Save up and then do it all together.
  11. Jan 10, 2018 at 4:06 PM
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Wheel spacers? Then you could keep your stock wheels.. which sport wheels are 16 inches I believe....
  12. Jan 10, 2018 at 4:10 PM
    LUCKxxJesusJNJ
    I’m not sure the current specs
  13. Jan 10, 2018 at 4:20 PM
    MCDavis
    RIC, VA
    Not trying to be hard on ya, but you have some more planning and research to do before dropping any coin.
    The size and offset are stamped into the backside of the wheels. Take one off and explore.
  14. Jan 10, 2018 at 4:46 PM
    LUCKxxJesusJNJ
    Yes I definitely do I was just going to bring it to a shop and tell them what I wanted done and go from there
  15. Jan 10, 2018 at 5:29 PM
    kluge9
    kluge9 Well-Known Member
    Andy
    19 DCSB OR MT
    Sports sport a 17” wheel. OR’s sport the 16”
    2k4Taco[QUOTED] likes this.
