How will these rims work?
Discussion in 'Street Trucks' started by Mr.Schertz, Apr 28, 2013.
  1. Apr 28, 2013 at 8:26 AM
    Mr.Schertz
    Mr.Schertz [OP] Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
  2. Apr 28, 2013 at 8:28 AM
    Large
    Large Red
    Link don't work.
  3. Apr 28, 2013 at 9:03 AM
    Mr.Schertz
    TEXAS
  4. Apr 28, 2013 at 9:04 AM
    Mr.Schertz
    TEXAS
    I see the offer a 17x8 with a 35 back spacing those should work out real good
  5. Apr 28, 2013 at 10:20 AM
    Brendo Ballz808
    Brendo Ballz808 Slammed or lifted.. ANYTHING IS BETTER THAN STOCK
    BRENDEN
    Oahu
    SNOFLAKE
    Check out my build:)
    You should be fine x runner wheels are 18x8 +30 5 mm in you won't poke at all
    What size tire u looking to run?
  6. Apr 28, 2013 at 2:02 PM
    Mr.Schertz
    TEXAS
    Not sure,I want the xrunner rims but cant find them. Its hard to find a rim with 30-40mm offset. I will most likely end up with a 16-18in rim with more of a street tire because the 5 luggers are setup for more of a car rim instead of a truck rim. I think the 5 lugs are a great truck,just the right size. I just want the right rim and right tire with the right stance,I want that real clean,sharp look. I plan on adding the bilstiens all around that go on the x-runner.
  7. Apr 28, 2013 at 5:17 PM
    Hot Taco
    Hot Taco Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
  8. Apr 28, 2013 at 5:21 PM
    TherealScuba
    TherealScuba Well-Known Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Only one place in the world they spell a city name like Schertz.
    Small world, used to live there.
    /off topic.
  9. Apr 28, 2013 at 5:28 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Click it a 2nd time.
    Discount tire frequently does that.
  10. Apr 28, 2013 at 5:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  11. Apr 28, 2013 at 5:37 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
    Id say run a 18 if you can I personally feel running 16 or 17 still shows alot of tire even if its a small stock height tire
    18's on 245/45/18 or 255/45/18 would be prefect for a street look without being on rubber band tires
    are you planning on lowering the truck?
  12. Apr 28, 2013 at 8:41 PM
    Mr.Schertz
    TEXAS
    No,other than the minimal(if any) drop I'll get with the bilstiens
  13. Apr 28, 2013 at 8:43 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
  14. Apr 28, 2013 at 8:46 PM
    Mr.Schertz
    TEXAS
  15. Apr 28, 2013 at 8:47 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That looks sharp 07.
  16. Apr 28, 2013 at 8:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You're looking at almost that for the Gassers.... save up a bit longer, or save on the spare and go with an 18" steelie.
  17. Apr 28, 2013 at 8:49 PM
    Brendo Ballz808
    BRENDEN
    Oahu
    SNOFLAKE
  18. Apr 28, 2013 at 8:51 PM
    07TacoRidah
    Pasadena CA
    :D I'm starting to get the hang of using manual on the DLSR. would have been better if I had washed the truck :p
  19. Apr 28, 2013 at 8:52 PM
    07TacoRidah
    Pasadena CA
    :D:D:D it's addicting!!!!! nah I figured out how to fix it though ;)
  20. Apr 28, 2013 at 9:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Is that with just the LCA spacers?
