How would I be able to tell if the previous owner did the ECGS bushing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OldManTacoFeels, Oct 7, 2020.
  1. Oct 7, 2020 at 12:15 PM
    OldManTacoFeels
    OldManTacoFeels [OP] The bells of tacos
    Billy Jr.
    2012 DCLB SR5
    Bilstein 5100s, AFE dry intake, Icon AAL pack, Bed stiffeners, and ideally some UCAs soon
    Thinking about lifting my truck to 2.5” over stock in the front. I’m at 1.5” right now with no vibrations. When I bought the truck it was a trade in and the previous owner had some tow controls installed upfront and 5100s set at 0. Wondering how likely it is that he or she did the ecgs bushing or not. I bought the truck with 110k on It
  2. Oct 7, 2020 at 12:22 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Pretty unlikely it has been changed with that setup.....stock UCAs?
  3. Oct 7, 2020 at 12:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are coil springs stock?
    If they NOT stock springs, it’s not usually advised to run the 5100 on anything but “0” setting.
    As for the Bushing?
    I don’t know of a way to tell besides pulling the axle?
  4. Oct 7, 2020 at 12:49 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    Yes on stock springs and UCAs. I’m betting it hasn’t been changed but there’s some easy way to tell I wanted to see before I order the parts
  5. Oct 7, 2020 at 1:15 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Since you are planning to lift it to +2.5" I would just plan on doing it. Replace the seal and service/oil change.
    gsubioguy and TnShooter like this.
  6. Oct 7, 2020 at 1:53 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    I’ve done brake pads, leaf springs, and rear shocks before, will replacing the bushing be too difficult or nah?
  7. Oct 7, 2020 at 2:01 PM
    TnShooter
    Deogee
    STOCK
    If you can manage to get the CV out, you pretty much have it made.
    I personally haven’t done one, but it looks pretty straight forward.
    Get the bearing puller, or borrow it, and it should be fairly easy.
    Most guys have problems with Removing or Installing the CV.
    OldManTacoFeels[OP] likes this.
  8. Oct 7, 2020 at 2:06 PM
    OldManTacoFeels
    Billy Jr.
    2012 DCLB SR5
    I’m Prbly gunna go for it because I wanna know how to replace CVs anyway and worse case scenario I buy someone beer to come help me
    gsubioguy likes this.
  9. Oct 7, 2020 at 2:07 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The axle nut installation requires 172 ft lb. 35mm socket. Suggest to watch several installation videos (YouTube).
    Natetroknot, TnShooter and gsubioguy like this.
  10. Oct 7, 2020 at 2:13 PM
    TnShooter
    Deogee
    STOCK
    Natetroknot likes this.
  11. Oct 7, 2020 at 2:15 PM
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Watch the videos & its pretty straight forward. When you order the bushing go ahead & order the seal as well. @ 100k, might as well replace it while the axle is out.
  12. Oct 7, 2020 at 2:19 PM
    TnShooter
    Deogee
    STOCK
    I suppose if you want to go all out, there is a seal on the back of the spindle and on the CV.
    You could replace those as well, your right there at them. And it wouldn’t be any easier any other time.
    I replaced mine when I did the wheel bearings.
    Actually, I didn’t replace the one on the CV, as I didn’t have the right one.
    And I didn’t have the time or resources to get one. I had to get my truck done QUICK.
  13. Oct 7, 2020 at 2:30 PM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I had a zip tie break on me once installing coilovers and UCA's, those 2 LBJ bolts out, everything apart, tie rods off, and if I remember right the half shaft pulled right out of the diff. One of my first lift installs and I about shat me pants, hahahaha.
    Point is I think its definitely possible to get out that way but, asyou said, probably not a great idea :thumbsup:
    TnShooter[QUOTED] likes this.
  14. Oct 7, 2020 at 2:30 PM
    oakcity
    oakcity Well-Known Member
    Jesse
    Raleigh, North Carolina
    2009 Grey Tacoma AC 4x4
    Money Pit
    Nah I have never don’t any front end work before but I’ve turned hella wrenches and I did the ECGS bushing, which included pulling my CV and I installed the whole lift kit and UCAs, and front bearings in one weekend. There’s a dude on YouTube I like called KFlo he has a ton of Tacoma videos including the bearing I follow most of his because he has a nice voice and feels like a normal dude doing normal stuff haha just get all the right tools and follow all the videos. I usually watch 27.398 videos before I attempt anything. Toyota makes everything pretty easy to pull apart. The CV I took a pry bar and it popped out in like 2-4 whacks and went back the same. Pulling the needle bearing was stressful because I popped so loud when it broke free and then came right out. I didn’t replace my seal as I only had 70k on it and I tapped the clamshell in with a socket that fit perfectly
