How would i go about to find better brakes for my taco.
Discussion in 'Technical Chat' started by Mitchdrum, Jul 16, 2018.
  1. Jul 16, 2018 at 4:19 PM
    Mitchdrum
    Mitchdrum [OP] New Member
    Mitchell
    Gainesville, Fl
    2004 4door 3.4L v6
    I tried searching for some but there were just so many on every website i went to. I was hoping someone here can help me find some good ones.
  2. Jul 16, 2018 at 4:26 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Tundra brake swap. Bolts right on if you get the brake line kit that is made for the swap. Even if you don't get the brake line kit for the swap, adapting the brake lines is easy. Lots of threads on them here & on other forums.
    Otherwise it's basically just upgrading to better pads. Slotted, drilled, or whatever rotors won't make a huge difference unless you are currently running crap quality rotors
  3. Jul 24, 2018 at 6:35 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Tundra brakes all the way. Makes a significant difference in braking and handling.
