How would this look?
Discussion in 'Wheels & Tires' started by 375taco, May 20, 2010.
  1. May 20, 2010 at 1:08 AM
    375taco
    375taco [OP] controlled pair?
    2010 TRD Sport 4x4 DC SB
    OME lift w/ 1" spacer. Built Right UCA's. Tinted all the way around. De-badged. Trimming up front
    I am thinking of going 17x8 or 17x10 I ask how it would look because im going to put on 33x12.50x17. I was going to go with a 18x9 rim but i think the 18" rim might be a little too big for the 33" tire. I was wondering if the 17x10's would be too wide for the truck. I am going with a 3" lift and AAL in the rear. I will trim for rub issues, I was just wondering if the tires would stick out too far? the rim doesn't come in 17x9 or thats what i would choose. The offset on the 17x8: -21mm 4.65" offset the 17x8: -4mm 4.25" offset I want the tire to stick out a little bit but not too much. I want a nice stance for the truck and I like the tire/rim not to be tucked inside the fender well. Maybe like an inch outside the fender, just so it has an agressive stance. The tires i will run are the new General Grabber's. http://www.4wheelparts.com/Tires/33...6&t_pt=101129&t_pl=102364&t_pn=GEN04568170000
    Here is the link to the tire. Let me know what you think. I like the tire. I know its new and there isn't much about it...I will let you guys know what I think. Thanks for the input. RLTW
  2. May 20, 2010 at 9:55 AM
    375taco
    bad time to post let me know what you guys think
  3. May 20, 2010 at 1:58 PM
    dgr540
    dgr540 I've got the FUNK
    Friendswood, TX
    2013 Wrangler Unlimited
    XDs Trail grappler 35x12.5x18 Winch 8K lbs Front bumper 4in Lift
    I just saw those earlier and I thought the wear cool. A little more than I want to spend.
