How would you convert a 4WD to a PreRunner ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Aug 21, 2015.
  1. Oct 31, 2015 at 3:37 PM
    #141
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Combine bad tires with severely worn tie rod ends, paint the windshield black, and remove all brake fluid.
    It'll handle snow worse than the most worn out Prerunner.
    DoorDing likes this.
  2. Oct 31, 2015 at 5:20 PM
    #142
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hmmm....build it sort of like mine? Perhaps.... :anonymous:
  3. Oct 31, 2015 at 6:24 PM
    #143
    NM Lance
    NM Lance Well-Known Member
    Dang it DoorDing, now you've gone too far!
  4. Oct 31, 2015 at 6:27 PM
    #144
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Baseball cards attached to the water pump, where the fan blades will hit 'em. You'll get a sporty Bbbbbbbbbbrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr!!!!!!!!!!!!!!!!! sound at moderate RPM's.
    DCLBFTW and DoorDing like this.
  5. Oct 31, 2015 at 8:09 PM
    #145
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    You should stick with your current neurosis and only upgrade when Toyota comes out with a diesel.
  6. Nov 1, 2015 at 3:06 AM
    #146
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Only, and I mean ONLY wher you start th bemoan the lack of a rear window defroster....
  7. Nov 1, 2015 at 7:50 AM
    #147
    Pigpen
    Dan
    Northwest Montana
    For a better sound, moar powar, and amazing throttle response, just remove the air filter. :mudding:
  8. Nov 1, 2015 at 7:59 AM
    #148
    Nacho Daddy's Taco
    Nacho Daddy's Taco Well-Known Member
    Austin, TX
    2017 Tacoma SR Double Cab Prerunner 4CYL Auto MGM
    2017 4Runner Trail Wheels Billstein 5100s @ 1.1 w/ 1.5" rear block 265/70/17 Cooper HTP
    I'm still waiting for instructions for Prius drivetrain swap plz thx
  9. Nov 1, 2015 at 8:00 AM
    #149
    Nacho Daddy's Taco
    Austin, TX
    FWD only plz thx
  10. Nov 1, 2015 at 9:25 AM
    #150
    Nacho Daddy's Taco
    Austin, TX
  11. Nov 1, 2015 at 9:27 AM
    #151
    Nacho Daddy's Taco
    Austin, TX
    And same off-road specs as the TRD Pro, correct?
  12. Nov 1, 2015 at 9:38 AM
    #152
    Nacho Daddy's Taco
    Austin, TX
    AND I just read these take 38x12.50 no trimming and my good buddy's shop said the TRD supercharger will "probably" work as well if im not mistaken IMHO
  13. Nov 1, 2015 at 10:57 AM
    #153
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    All these mods are making me feel........dirty.
  14. Nov 1, 2015 at 6:36 PM
    #154
    Wadar
    Wadar Not Well Know, But Shows Up From Time to Time.
    Wade
    Western Slope, Colorado
    ‘02 XC TRD-OR, & ‘20 DCSB TRD-OR
    A few.
    They'll work best if constructed from from plywood and 2x4's. At the same time adding a vertical stabilizer would increase cornering traction and efficiency. I'd recommend 1/2" CDX for the best strength to weight ratio, and rough sawn doug fir 2x4's for a rustic look.
  15. Nov 1, 2015 at 6:41 PM
    #155
    Wadar
    Wade
    A few.
    Absolutely brilliant! Perfect way to reduce the drag coefficient!
  16. Nov 1, 2015 at 7:05 PM
    #156
    Pigpen
    Dan
    Northwest Montana
    When I carry my canoe on the truck is it best to strap it to the rack bars, or route the straps all the way under the truck?
  17. Nov 1, 2015 at 7:08 PM
    #157
    Wadar
    Wade
    A few.
    I like to strap my canoe under the truck, helps with water crossings.
  18. Nov 1, 2015 at 7:10 PM
    #158
    Pigpen
    Dan
    Northwest Montana
    I had a (coincidentally,female) friend strap a mattress on this way. She couldn't figure out why the straps kept breaking shortly after she started driving.
  19. Nov 1, 2015 at 7:28 PM
    #159
    Wadar
    Wade
    A few.
    Under the truck? :notsure:
  20. Nov 1, 2015 at 7:34 PM
    #160
    Pigpen
    Dan
    Northwest Montana
    This one would like that
