How would you hook up a second horn?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ToyotaKTMracing, Apr 2, 2012.
  1. Apr 2, 2012 at 8:09 PM
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    Thinking about getting a klaxon horn hooked up to a separate switch. How could I wire it up?
  2. Apr 2, 2012 at 8:15 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Or a cow horn
  3. Apr 2, 2012 at 8:18 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Look up the basic wiring for aux lights. Wire it the same way, with a horn in place of the lights. It's not unheard of for a horn to need 15-20 amps, so use 14 gauge wire. Use a momentary switch of your choice to activate a separate relay.
  4. Apr 2, 2012 at 8:22 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Alright. I figured it would be like lighting.
  5. Apr 2, 2012 at 8:34 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Which fuse could I use? I would want it hooked up to a fuse. I need to find a diagram of the fuse box and which ones are which? And how could I run a wire to the switch in the cab? I've never really done wiring.
  6. Apr 2, 2012 at 8:48 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You need to add a new fuse at the battery. If you buy an aux light wiring kit designed for two 100 watt lights from the auto parts store, it will come with a fuse holder, fuse, relay, and wiring that should be easy to adapt to your new horn. You'd just have to swap the switch for a momentary one.
    The stock fuse box won't have enough reserve to tap a new horn into. They do pull some juice.
  7. Apr 2, 2012 at 8:48 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Run to a local autoparts store (we have PepBoys in my area) and they should have the add-a-fuse kits. I'll check which fuse I used to illuminate my hella switch tomorrow morning. Autoparts stores should carry different kinds of relays too.
    This thread should help as well: http://www.tacomaworld.com/forum/lighting/205143-add-circuit-fuse-question.html
    Edit: above post is correct - the fuse will only be good for powering an illuminated swith. Sorry if my reply was misleading
  8. Apr 2, 2012 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.tacomaworld.com/forum/technical-chat/103969-electronics-basics-reference.html
    Good info here.
    I would wire in a new inline 20 amp fuse at the battery, run 14 gauge wire to a 30amp relay, then to the new horn. You can also wire the relay's coil "control voltage" to the incoming power from your new fuse. Then run another wire through the firewall to a momentary switch that will ground the wire to activate the relay's coil, and trigger the horn. Keep in mind that you must use 14 gauge wire or better in the entire circuit if you are relying on the 20 amp fuse for the horn and the relay control circuit.
  9. Apr 2, 2012 at 8:52 PM
    ToyotaKTMracing
    Shay
    West Virginia
  10. Apr 2, 2012 at 8:54 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  11. Apr 2, 2012 at 8:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I suppose he could try that. The one time I tried it, I blew the factory fuse. I was adding the new horn in addition to the existing one. That sounds like what the OP is going to do also.
    I actually ended up doing as I suggest above, but I used the factory horn circuit as a trigger. So hitting the horn button activated the factory horn and the aftermarket one at the same time.
  12. Apr 2, 2012 at 9:04 PM
    08pretaco
    Oliver
    az
    you could just add an inline fuse between the aftermarket horn and where you tap into the factory wiring.
    not saying any idea is better/worse than the other, just trying to throw possible options out there!
    post up how you ended up doing it OP! :thumbsup:
  13. Apr 2, 2012 at 9:17 PM
    ToyotaKTMracing
    Shay
    West Virginia
    This is for future reference if I do this. Not 100% sure if I will or not. If I do, pics will follow
  14. Apr 2, 2012 at 9:23 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I just need to fing a good klaxon. Prefer under $30
  15. Apr 2, 2012 at 9:29 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No, you can't.
    ---(FUSE)---(HORN)
    xxxxxxxxxxx\---(FUSE)---(HORN) = Still drawing two horns from the factory fuse.
    It MUST be wired properly. High current + small wire = burned truck.
    The fuse is not there to protect the horn. The fuse is there to protect the wiring harness and needs to be as close to the battery as possible.
    Listen to Joe. Wire it EXACTLY like aux lighting, but use a momentary switch to trigger the relay. That is the only SAFE way to do it.
  16. Apr 2, 2012 at 9:33 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I plan on doing what Joe said if I add a horn.
  17. Apr 2, 2012 at 9:45 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    anyone know of cool sounding horns?
  18. Apr 2, 2012 at 9:49 PM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Shay,
    Found "Chrome Ahh-ooo-gah Horn" on Amazon.com for $24.95 plus shipping. Also found a "Wolf Whistle" there that sure would make your Taco unique:D. Good luck getting the electricals ironed out. Let us see some photos of how you complete the horn mods.
  19. Apr 2, 2012 at 9:56 PM
    08pretaco
    Oliver
    az
    Damn, didnt realize still draws from the same fuse that way. :eek:
    fuses are over-rated :p everyone likes a good fireworks show
  20. Apr 3, 2012 at 7:36 AM
    ToyotaKTMracing
    Shay
    West Virginia
    Thanks! The reviews on it seem okay. It just sucks you can't find one that actually sounds like original antique horns without spending a lot.
