How would you load a deer by yourself?
Discussion in 'Off-Topic Discussion' started by Notoneiota, Dec 10, 2020.
  1. Dec 11, 2020 at 6:41 AM
    #41
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Ranger roll into a fireman carry!
    Seriously, good on you to not let this go to waste. Its not easy doing this by yourself and I've done it many times. I agree with what others have said about using a ratchet strap though. I hookup at one of the corners in the bed and as I lift one end up (usually the head side) I tighten the strap so I don't lose any gains.
    Eventually, I strap up the back end and give it a strained lift using knees.
    Dead weight sucks, but I'm better prepared now with a truss on the bed for higher angle use with straps. As a matter of fact, I have those auto retractable straps bolted on the truss so it retracts as I lift!
    Gunshot-6A, Bigdaddy4760 and wilcam47 like this.
  2. Dec 11, 2020 at 6:57 AM
    #42
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Road kill around here usually isn't worth picking up.
    Last year someone hit a doe in front of my house. There was a giant blood pool, the stomach laying in the middle of the road, and a mess in the ditch 50' away. I found you the guy that hit it in a small SUV just kept going on to work. All it did was break a turn signal. :eek: I was sure that the vehicle would have a LOT of damage.
    Bigdaddy4760 likes this.
  3. Dec 11, 2020 at 7:04 AM
    #43
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    My first thought like many others would be knock the guts out of it. I'm the same size as OP but when absolutely necessary for strength....I summons the demon
  4. Dec 11, 2020 at 8:16 AM
    #44
    Front sight
    Front sight Well-Known Member
    SW Florida
    06 Prerunner TRD Sport
    Full OME 3"lift, LR UCA's,Destination 285/70/17's, 1.25 spidertrax, K&N drop in, 2nd filter removed, Weathertech liners, Toyota bed mat, reverse lights,Wet Oklee's, bedlights and other small stuff.
    Bucks don’t seem to give me a problem loading in. Does are a fight. Having a topper makes it worse. I shot one this season and I had to belly to back suplex it onto the tailgate. I was covered in blood but got the job done. The weight of the deer wasn’t the problem. It was getting ahold of it to get it up.
    tacotoe, Bigdaddy4760 and wilcam47 like this.
  5. Dec 15, 2020 at 10:01 AM
    #45
    virginiamarine
    Northern Virginia
    Saw this on the highway this morning and realized it's perfect for the challenge!!! You can just strap it to the side of the inside bed when not in use probably.
  6. Dec 15, 2020 at 12:54 PM
    #46
    jflanders72
    jflanders72 Member
    New England
    2014 Tacoma, Double Cab, SR5
    I always carry a come-along and rope...just in case
    CaptainBart45 likes this.
  7. Dec 15, 2020 at 1:23 PM
    #47
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Next to Home Depot. Go in buy an 8' 2X6. Then anchor a ratchet strap to the bed, strap over the end of the 2X, cinch the legs with strap, stand the 2X vertical on the bed. This will act like a boom on a crane. Ratchet away. Ratchet gets full, use a 2nd strap and rig that. Repeat. It'll load.
    I was able to move a concrete slab 24x48x4 on my own using this method. The slab was well over 300 lb. I'm 60 yo. Haven't told the wife how I did it. I just told her I ate my Popeye spinach.
    06Tacooo likes this.
  8. Dec 15, 2020 at 1:27 PM
    #48
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I would laugh at someone doing that to deer on the side of the road. I would laugh harder at anyone doing that in a gun fight. It would almost be worth hazing said individual IN said gunfight.
    Gunshot-6A likes this.
  9. Dec 15, 2020 at 6:21 PM
    #49
    Notoneiota
    Notoneiota [OP] Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I've done a lot of thinking on this since the experience and I've concluded that hogtie-ing it in a tight bundle would probably have helped considerably. The key being to get the head and legs pulled together so less is flopping around as you're pulling it in.
    I may keep some better straps and a come-along in the back with maybe even a strip of plywood or a board or two to use as a ramp.
    This type of thing doesn't happen too often - and I usually have someone to help when I'm hunting - but this taught me I need to be a little more self-reliant and resourceful.
    Thanks for the suggestions.
    Oh, and as for the Ranger roll...I'm not going to do it, but I'd like to see someone try. Who can we get to do it and post it on Tic Tac or whatever video dealy the kids use these days?
  10. Dec 15, 2020 at 6:26 PM
    #50
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    This works amazing for dragging one out and if you stand on the tailgate you can pull it right up in the bed of the truck by yourself no problem. Its basically a water ski tow rope but works amazingly well.Screenshot_20201215-212410_Amazon Shopping.jpg
  11. Dec 15, 2020 at 7:20 PM
    #51
    Notoneiota
    Oakdale, MN
    I actually have a water-ski handle/rope that I set aside to drag deer with and I NEVER have it with me when I need it. Every year I throw it in the truck with my hunting gear and every year it is not with me in the woods when I need it. And this year I left it in the garage.
  12. Dec 15, 2020 at 7:30 PM
    #52
    FFBlack
    2019 TRD OFF ROAD
    Got to put that shit in the pack, man. My basic essentials hunting items are gun,bullets, a knife and this rope.
  13. Dec 15, 2020 at 7:34 PM
    #53
    Notoneiota
    Oakdale, MN
    Everyone knows if you leave the rope and knife behind, you're going to shoot a monster buck. I've never personally experienced this, but I've heard it told.
  14. Dec 15, 2020 at 7:39 PM
    #54
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
