How would you redesign 4th Gen Tacomas?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jetfishn, Jan 1, 2021.
  1. Jan 3, 2021 at 10:15 AM
    #181
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Passenger side shower/shitter combo
    Junkhead and arrakis429 like this.
  2. Jan 3, 2021 at 10:22 AM
    #182
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Now this was a reasonable post.
    BSFord likes this.
  3. Jan 3, 2021 at 10:40 AM
    #183
    44-16 Taco
    44-16 Taco Do I look like a guy with a plan?
    KMS
    2017 SuperWhite DCORSB
    https://youtu.be/qM5HMMXNCoc
  4. Jan 3, 2021 at 10:47 AM
    #184
    Itchyfeet
    Itchyfeet Well-Known Member
    Where I take issue with the rear drums is despite Toyota dicking around with them for decades the rear e-brake set up is designed to last only in dry climates. To add insult to injury the rear axle bearing and seal design is just trash and is designed to pretty much be a PITA to service.
    It's time for Toyota to ditch this crap. The rear axle vent is also trash they've pretty much been using the same part number since 1984.
    shakerhood[QUOTED] likes this.
  5. Jan 3, 2021 at 10:48 AM
    #185
    davidstacoma
    David
    NC
    Done.
  6. Jan 3, 2021 at 10:49 AM
    #186
    n2xlr8n
    n2xlr8n Well-Known Member
    still looking
    Put a HD 8 speed AT in it, dump the current variable cam timing / fueling / ignition mapping, and hire a group capable of tuning modern DI/FI engines.
    And redesign the "limited slip rear diff" us non-TRD owners have to live with until we install a locker.
    Other than that, I absolutely love this truck.
  7. Jan 3, 2021 at 11:16 AM
    #187
    07RedTacoDawg
    07RedTacoDawg Well-Known Member
    Danny
    Jamestown , NC
    07 Red Tacoma
    2 inch lift , tires and wheels
    They should put huge signs on the transmission and oil pan so no one can " accidentally" drain the wrong one anymore.
    OmahaJeff, Junkhead and n2xlr8n like this.
  8. Jan 3, 2021 at 11:46 AM
    #188
    n2xlr8n
    still looking
    No, just a real limited slip or, oh my, a locking differential.
    My Raptor made 675 whp, but it was not usable under 30 mph due to wheel hop.
    I'll take usable traction and area under the curve in any vehicle over tire shredding, un-hookable HP.
  9. Jan 3, 2021 at 11:52 AM
    #189
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Inline six. Yep.
    Dbarffish and Steadfast like this.
  10. Jan 3, 2021 at 11:55 AM
    #190
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I think the rear drums should go. Why? Uniformity, the back does not match the front. 4Runner and Tundra work fine with rear discs.
    They say drums are better than discs offroad. They also say 99% of OR owners don't take their OR Tacoma off road.
    I doubt if Toyota has the offroad market in mind when they claim drums are better offroad even if drums are better offroad.
  11. Jan 3, 2021 at 11:55 AM
    #191
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Are you overweight by chance?
    Never had an issue with the seat not being supportive or a cramped footbox on 12 hour drives.
  12. Jan 3, 2021 at 12:01 PM
    #192
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    They're not going to give us anything we want for 4th gen. It needs:
    750w minimum inverter
    no more halogens
    Power rear slider and sunroof for access cab
    Second bed cubby/front rail standard
    Bumper line that ends where an aftermarket bumper goes instead of under the lights so there's no cutting (but why would they care about that?)
    MOAR power
  13. Jan 3, 2021 at 12:29 PM
    #193
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    7 speed manual with 2lo built into transfer case. V6 engine.
    whiseve, OmahaJeff, Junkhead and 3 others like this.
  14. Jan 3, 2021 at 12:43 PM
    #194
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    4 link rear 22” travel (with sway-bar duh)
    16” travel up front with working 4wd
    redesigned subframe for more strength and higher ground clearance.
    stock 35” tires with room for 39” upgrades
    1” lower ride height vs the current ride height
    Joint venture with one of the major shock brands to develop one 3” coil over per wheel , with active valving control like some of the side by sides have so the truck is street and dirt friendly.
    Then and only then can Toyota finally slap the “prerunner” badge on the tailgate (yes it will have a bed too)
  15. Jan 3, 2021 at 12:53 PM
    #195
    Gyres01
    Gyres01 Well-Known Member
    Todd
    Bastrop, TX
    19' Silver TRD Sport
    ...well if it's looks like the next Tundra....Idk.
  16. Jan 3, 2021 at 12:56 PM
    #196
    farmtacoma
    farmtacoma Date Farmer
    Julia
    Twentynine Palms, California
    2021 Cement TRD OR DCLB 4x4 & 2018 Silver SR ACLB 4x2
    When do you guys expect 4th gen to come out ?
    I heard super bowl will show New Tundra
  17. Jan 3, 2021 at 12:59 PM
    #197
    BarcelonaTom67
    BarcelonaTom67 Lost in Translation....
    Tom
    Laurel County, Kentucky
    2017 Barcelona Red Off-Road DCSB M/T
    Allow manual transmissions with long bed combo.
    Maybe re-design the cab mount so that it doesn't need to be chopped in order to fit tires >33".
    Junkhead and specter208 like this.
  18. Jan 3, 2021 at 1:34 PM
    #198
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    Ok I guess I’ll dream...
    I want it to be a 3 or 4 liter diesel, it should accelerate like a diesel X5 and get 20 highway mpg with 37s. The ZF 8 speed auto is pretty sweet or a manual transmission with a super low crawl 1st gear. I’ll take solid axles, auto disconnect sway bars and selectable lockers front and rear. I also want the option to fully deactivate all the safety stuff when desired. Also it needs to have a 30 gallon fuel tank so range isn’t a problem. Give me all that and I could over look the rear seat leg room, crappy entune and lack luster speakers.
    Basically I want a Tacoma body with a Power Wagon/X5 drivetrain and the wheel tire combo needs to fit any thing as easy as a JK does.
  19. Jan 3, 2021 at 1:41 PM
    #199
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    2016 TRD Sport access cab 4x4 auto
    Black tube steps,mud flaps, fluid filmed tonneau cover,jbl speakers heated leather seat covers,bed mat,husky floor liners
    Electric tacoma with a torque converter transmission.
    daveeasa likes this.
  20. Jan 3, 2021 at 5:30 PM
    #200
    44-16 Taco
    KMS
    Clearly they should give everybody who buys one a stimulus rebate
    Junkhead likes this.
