How Would You Remove This Oxygen Sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongEnoughCrazy, Jul 29, 2024.
  1. Jul 30, 2024 at 8:45 AM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    No truck was bought in Long Island NY. Its the standard rear O2 sensor.... just has the heat shield still intact.
    Black97v6MT[QUOTED] likes this.
  2. Aug 1, 2024 at 2:48 PM
    LongEnoughCrazy
    LongEnoughCrazy [OP] Active Member
    I started the truck, crawled under, and narrowly avoided burning myself on the scalding-hot exhaust pipe.
    The area around the sensor seems hotter than other parts of the pipe, but I didn't feel a gust of exhaust.
    Guess I'll try @Currygoat 's filing method first before moving to more complicated techniques.
    I also took a look at the downstream sensor. It seems in much better shape. I can actually see the nuts.
    Currygoat and ControlCar[QUOTED] like this.
  3. Aug 1, 2024 at 3:37 PM
    Currygoat
    Should be easy. Takes about 5 minutes of gentle filing to cut through the nut without damaging the stud. A new sharp file makes things easy here.
    Edit: You can also file two sides straight... then back it off with small wrench.
  4. Aug 1, 2024 at 4:17 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    After you get the old stuff off clean the threads on the studs. Use some anti seize when installing new nuts. I just replaced my o2 sensor today. One nut stripped on the stud, a bit of a pain but I was able to get it off. I used a die to clean up the stud threads before installing the new sensor
  5. Aug 1, 2024 at 4:21 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Speaking of anti seize...if you don't have any get the stuff in the stick. It's like anti seize in a deodorant container. They should have done it decades ago...
  6. Aug 1, 2024 at 4:29 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Is the copper anti seize the Best for the hot apps?
  7. Aug 1, 2024 at 4:31 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    I use kopr kote, I have many jars left from work. Good stuff.
  8. Aug 1, 2024 at 4:32 PM
    MadNachos
  9. Aug 1, 2024 at 4:32 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Embezzling kopr kote?
    Lol
    MadNachos likes this.
  10. Aug 1, 2024 at 4:35 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Yup, among many other things.
  11. Aug 1, 2024 at 4:40 PM
    MadNachos
    So....what ya got?
  12. Aug 1, 2024 at 4:41 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    FYI I bought a Denso o2 sensor from Home Depot online for $54.00 after mil discount. Good price.
  13. Aug 1, 2024 at 4:42 PM
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    list is too long.
  14. Aug 1, 2024 at 4:50 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Weak!,
  15. Aug 1, 2024 at 4:54 PM
    #35
    HoneyBadger153
    HoneyBadger153 Well-Known Member
    Lowcountry, SC
    2002 Lunar Mist Tacoma SR5 4WD
    ARB, Hella FF75, SoftTopper, Power Limited Seats, OME Suspension, Heated Mirrors
    Seems like there's a good number of O2 sensor replacement posts lately. Just had to do mine a couple weeks ago. As others have said, Craftsman bolt extractor. I ended up having to put the #4 socket on, tap it on with a hammer and grip it with Vice Grips. The rear one is what gave me the issue due to the heat shield. Ended up using tin snips and just chomped away at it
  16. Aug 2, 2024 at 9:32 AM
    #36
    LongEnoughCrazy
    That's $70 cheaper than Rock Auto. Are you able to link us to it? I don't see it on the HD website.
  17. Aug 2, 2024 at 9:54 AM
    #37
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Home Depot sku for denso o2 sensor:
    1005383749
  18. Aug 2, 2024 at 10:12 AM
    #38
    LongEnoughCrazy
    Ok, that's the downstream sensor. I need upstream.
  19. Aug 2, 2024 at 11:05 AM
    #39
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Upstream is air/fuel sensor
    LongEnoughCrazy[OP] likes this.
  20. Aug 2, 2024 at 1:10 PM
    #40
    LongEnoughCrazy
    Ok I guess I got the nomenclature wrong then. Thanks.
