How Would You Remove This Oxygen Sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by LongEnoughCrazy, Jul 29, 2024.
  1. Aug 11, 2024 at 7:14 AM
    #61
    F.I.LetsGoFishing
    F.I.LetsGoFishing Well-Known Member
    95.5 4wd 3rz mt
    Neglected Original
    An alternative that comes with high risk of burning yourself, is to drive or run truck for a while and strike while still hit but great care must be taken as everything will be hot
    JustADriver likes this.
  2. Aug 11, 2024 at 7:16 AM
    #62
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    strike hit with an air chisel?
  3. Aug 11, 2024 at 7:35 AM
    #63
    F.I.LetsGoFishing
    95.5 4wd 3rz mt
    Neglected Original
    Was meaning get under and use your wrenches while everything was still hot.
    I will set up on ramps and lay out my tools, drive around for 20 minutes or so and pull back up on the ramps and start work immediately. Just remember when setting up to include a pair of thick leather gloves as everything is danger hot
    Black97v6MT likes this.
  4. Aug 12, 2024 at 4:07 PM
    #64
    LongEnoughCrazy
    LongEnoughCrazy [OP] Active Member
    Local shop wants to charge me $124 for labor...just to remove the old sensor and put the new one on. Guess I'll be doing it myself!
  5. Aug 13, 2024 at 7:46 AM
    #65
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Honestly, $125 bucks isn't that bad. Especially considering you asked this questions 2 weeks ago, and it's still not done yet. I understand that a lot of people don't have the tools/workspace/resources on hand to tackle this, but if you did have everything you needed, you would have been able to do this already. If you have to buy something to complete this task, I'd suggest just paying the $125 and move on.
  6. Aug 13, 2024 at 8:43 AM
    #66
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    LongEnoughCrazy[OP] likes this.
  7. Aug 13, 2024 at 10:03 AM
    #67
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Knowing that the studs will probably be impossible to remove and at the end impossible to install a new O2 sensor, I'd probably just disconnect it (leave it in), and weld a new O2 bung right in front of it, at a maybe 20 degree shift. Replacement O2 sensors will have a flange threaded onto a standard thread that you can simply unscrew so you can thread the sensor into the bung
  8. Aug 14, 2024 at 2:50 AM
    #68
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    That’s a good deal IMO!
  9. Aug 14, 2024 at 7:40 AM
    #69
    LongEnoughCrazy
    At a minimum, I'd want to buy a floor jack (dislike bottle jack), a file set and some anti-seize.
    I like working on stuff. The reason it's taking so long is I have way too much going on in my life at the moment, and the Taco isn't my primary vehicle.
    F.I.LetsGoFishing and koditten like this.
  10. Aug 14, 2024 at 8:58 AM
    #70
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
    Then work on it a little at a time
  11. Aug 14, 2024 at 10:48 AM
    #71
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    what I did with mine is carefully cut the nuts in half with a dremel and split them open with a cold chisel (flat head screwdriver will do too).
    Don't forget to put antiseize on the studs when you'll screw the new nuts back. They'll be much easier to remove next time
  12. Aug 29, 2024 at 8:30 AM
    #72
    LongEnoughCrazy
    Upsteam and downstream sensors use identical hardware, correct?
  13. Aug 29, 2024 at 8:37 AM
    #73
    Parkvisitor
    Juan
    So Cal
    It’s a truck
    stuff
  14. Sep 5, 2024 at 9:08 AM
    #74
    LongEnoughCrazy
    Just spent my first hour under there with file set. There is no way I am filing the nut down to the point I can rip it off with pliers. I'm thinking maybe yours was more corroded than mine, or maybe my files are inferior to yours, or both?
    So now I've destroyed one of the nuts. Time to plot next move.
  15. Sep 5, 2024 at 10:02 AM
    #75
    545
    545 Well-Known Member
    2015 Access Cab
    Go spend the $125
  16. Sep 5, 2024 at 10:09 AM
    #76
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This thread is like a traffic accident...I just can't stop looking and waiting for the next step!
    :popcorn:
  17. Sep 5, 2024 at 10:51 AM
    #77
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Water and heat destroyed those nuts a long time ago, there's absolutely nothing you can do to make them worse.
    Grind 'em off and replace the studs, like we suggested forever ago.
  18. Sep 5, 2024 at 12:58 PM
    #78
    LongEnoughCrazy
    I'm saying I should have done the simplest thing first and just tried to beat on a smaller socket like @BroTaco8008 suggested. Yeah the photo in the OP looks bad, but probably there was enough of a nut left that I could have just unscrewed it with some elbow grease.
    Nope, this is fun for me.
    Pbfender15 and koditten like this.
