How would you seal up driver's side cubby to protect ARB compressor?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike402, Dec 1, 2021.
  1. Dec 1, 2021 at 10:56 AM
    Mike402
    Mike402 [OP] Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    So I installed an ARB dual compressor in the driver's cubby of my 20 OR. A pic right after it was installed - nice and new and clean
    A year and a half later it got so filthy and crusted with dirt/mud from wheeling out in the desert that it quit running. I pulled it all out and cleaned everything out including filters, but now I want to seal that area and also put in a top dust cover from Expedition Essentials.
    My question is - how would approach sealing this area up? Adhesive backed audio deadener? Home based insulation? Trying to figure the best material to use, and how to get it to adhere and hold up in that area. Latest pic for reference. You can see the opening which is totally exposed to elements/ rear tire.
  2. Dec 1, 2021 at 11:45 AM
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
    It looks like you cut out the bottom of the cubby to fit the ARB...leaving the whole bottom exposed and open to well behind the tire eh? Looks like you have high clearance bumper too? You could measure that space (below the ARB where the cubby box was) and look for a small flexible plastic/rubber tub that you could fit in there and bolt it to the bed and HC bumper and seal with flexible sealant. You're going to have to get lucky/creative to find something, but its possible. Just my 2 cents. That's were I'd start, good luck.
    vicali likes this.
  3. Dec 1, 2021 at 11:52 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Where's the rest of your cubby? It's possible to seal them up from dust if you haven't already chopped holes in it.
  4. Dec 1, 2021 at 12:40 PM
    Mike402
    Palm Springs, CA
    Yep cut to fit the expedition essentials mount, plus a Mobtown HC bumper. Since this was a 20, there was no original cubby, so required some surgery to the truck to get it to fit. All is well, just need to figure out a way to seal it.
    I was thinking of using Flex seal somehow. Hadn't thought of using some sort of tub though
  5. Dec 1, 2021 at 12:44 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    CaptainBart45 and Juisebocks like this.
  6. Dec 1, 2021 at 12:46 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'd look for an appropriate sized marine glove box of some sort. Or if you want to do it yourself maybe grab a plastic cooler, battery box, etc.
    Juisebocks likes this.
  7. Dec 1, 2021 at 12:57 PM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Marine stowage boxes and marine parts in general have very good protection against the ingress of debris.
    I had a water pump mounted in my stock stowage box and I holes in the bottom of my cubby for the hoses. I had to get some tight fitting panel grommets to keep the rocks, and crud out of the cubby.
    I have no idea how that would help you, but there it is.
  8. Dec 1, 2021 at 2:31 PM
    Mike402
    Palm Springs, CA
    Appreciate the responses, but if you look at the first pic in the OP, I already have a cubby installed that houses the compressor. There would not be room for any additional glove box or any sort of tub. Just need to figure out how to seal the one I have now. You can see behind it is exposed to the outside.
    Will check that out, thank you...
  9. Dec 1, 2021 at 2:40 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I would fabricate an aluminum or SS insert for the "cubby" space, and put the ARB in that. Do it right.. do it once. I have a really hard time seeing Flex-Seal and drywall tape standing up to any kind of off-road use.
  10. Dec 1, 2021 at 2:40 PM
    Juisebocks
    Drew
    "Stock+"
    Maybe I wasn't clear enough, my bad. Check these out as an example: https://www.amazon.com/dp/B08B1MMXMB/
    I meant that the storage containers built into boats have locking doors. Just find your style, color, and size then seal the the whole thing with black gasket maker before you mount it with rivnuts or whatever.
  11. Dec 1, 2021 at 2:42 PM
    Mike402
    Palm Springs, CA
    This is what I have in there now. I seriously doubt I could fabricate anything that would be an improvement. Just need to seal around this mount
  12. Dec 1, 2021 at 2:46 PM
    Mike402
    Palm Springs, CA
    Gotcha. I actually have the Mobtown locking cubby door for the front. I need to seal behind the existing compressor mount if that makes sense
    Juisebocks[QUOTED] likes this.
  13. Dec 1, 2021 at 2:46 PM
    Juisebocks
    Drew
    "Stock+"
    Wait, like, the whole top portion, not just the bed opening?
  14. Dec 1, 2021 at 2:49 PM
    Intrepid
    Intrepid Well-Known Member
    Jeff
    Toronto, Ontario CANADA
    2018 Tacoma TRD Sport double cab short box manual transmission cement grey
    ARE canopy with sliding screened windoors and rhino roof track, Warn semi-hidden winch mount with VR 10 winch, nightrider 28" single row LED lightbar, Hood scoop light bar, Anytime front and rear cameras. anytime Navigation switch, plug-in oil pan heater, plug-in block heater, plug-in battery blanket. WINTER: Snow Sport plow with back-drag modification, Bridgestone Blizzak DM V2 on steelies 265-70-17.
  15. Dec 1, 2021 at 2:49 PM
    Mike402
    Palm Springs, CA
    They make a dust cover that bolts at the top of that mount, which I have on the way. My problem is all the dirt/dust that gets in from the opening in the wheel well behind the cubby mount. So need to seal in between that area. As of right now, the mesh tape/flex seal idea seems to be the best option
  16. Dec 1, 2021 at 2:51 PM
    Mike402
    Palm Springs, CA
  17. Dec 1, 2021 at 2:52 PM
    Juisebocks
    Drew
    "Stock+"
    Agreed on the flex seal thing :101010:
  18. Dec 1, 2021 at 3:01 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I'd be looking toward a big Rubbermaid or Sterlite storage box that would encapsulate the entire exposure from the backside. Attach and seal its opening against the composite bed around the entire mount and apparatus.
    There are a zillion different dimensions of those things. Walk the aisle at Walmart, get creative. Maybe a Home Depot visit. Repurpose something made for an unrelated use.
  19. Dec 1, 2021 at 7:40 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Maybe just take it out and clean it from time to time. Have a couple of beers...
  20. Dec 2, 2021 at 5:43 AM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    I'd hesitate a bit on trying to make it "air tight".
    It's an air compressor. It needs to be able to take in ... Air.
    It also needs to shed heat.
    I completely get you wanting to minimize the amount of dirt/dust getting to it, but you should also consider providing it with some ways to get some airflow as part of your plan.
    gudujarlson, Intrepid and Jojee117 like this.
