Howl from roof under high lateral winds?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacodrone, Jan 26, 2013.
  1. Jan 26, 2013 at 8:14 AM
    tacodrone
    tacodrone [OP] Dust Cloud
    HTX
    12 DCSB SR5 4X4
    3" ProComp Nitro Lift, Bilstein 5100's, 33x11" AT-KO's, SpiderTrax 1.25" Spacers, MetalMiller Tire Mount
    Has anyone else experienced a loud, intermittent, "howl" from the roof under moderate to high lateral winds? I first experienced this yesterday, at speeds of 75 mph+, with occasional gusts of wind coming from the side of the truck at around 20mph.
    I don't mean a whistle, I mean a loud howl, bringing to mind the scream of a banshee, which seems to be located near the center-front of the roof. I first confused it for the sound of metal contacting metal, and nearly whipped over to the shoulder for an emergency stop before I realized the location.
    No roof rack on the vehicle, and I looked for any obvious breaks in the seals around the doors or the windshield, and found none. The truck is a fairly new (6k miles) '12 double cab, and I'd like to get to the bottom of this if I can, as the situation will only get worse during the coastal spring, where I'll be dealing with worse lateral winds =)
    TIA!
  2. Jan 26, 2013 at 8:54 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    Do you have a shell? I have a SnugTop on mine & have noticed this before. I didn't know what it was until a Toyota mechanic rode with me, heard it & determined it was the wind passing through the gap between the rear of the cab & the shell. I guess it was the only time I had been in that type/direction of wind on a stretch of highway I travel on daily. Haven't heard it since. We don't have windstorms like that day very often here.
  3. Jan 26, 2013 at 9:20 AM
    tacodrone
    HTX
    12 DCSB SR5 4X4
    Alas, no camper. It's really quite an odd sound, as there's no whistle to it at all. I guess banshee wail is a bit over-dramatic, it sound like an extremely loud vibration - closer to metal on metal. I'm wondering if it's just an odd property of the roof vibrating under the right conditions?
  4. Jan 26, 2013 at 9:23 AM
    03DBLCABTACO
    03DBLCABTACO Well-Known Member
    Dan
    Tomball TX
    Cavalry Blue 2019 TRD OFF-ROAD 4X4
    It is the windshield seal. See your dealer.
