Howling/roaring road noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redskinfan61, Dec 1, 2017.
  1. Dec 1, 2017 at 6:39 PM
    Redskinfan61
    Redskinfan61 [OP] Member
    Dan
    2007 SR5 Tacoma
    I have 09 Tacoma 4x4 , I have roaring road noise that really barks around 60/65 mph..I first thought it might be tires so I replaced them, still noise..I took it to Toyota dealership they said it was front wheel bearings so I replaced them, still roars...I think it is coming from drive shaft! Anyone had problems with drive shaft bearing? I am no mechanic put I think it is coming from drive shaft..any help would be appreciated..thanks
  2. Dec 1, 2017 at 6:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Needle bearing in front differential. Put in 4 wheel drive and see if it goes away.
    It's common.
    JoefromPTC likes this.
  3. Dec 1, 2017 at 7:16 PM
    Redskinfan61
    Dan
    2007 SR5 Tacoma
    Should the noise go away in 4x4?
  4. Dec 1, 2017 at 7:18 PM
    Redskinfan61
    Dan
    2007 SR5 Tacoma
    Should the noise go away in 4x4 if it's a bearing..
  5. Dec 1, 2017 at 7:21 PM
    koditten
    Kirk
    Central Michigan
    The noise should go away or be drastically reduced.
    There is a thread on this site. East Coast Bearing results or similar. It has much info on this issue.
    Edit: it's ECGS. East Coast Gear Supply for Toyota. You will find lots of info.
  6. Dec 1, 2017 at 8:12 PM
    Redskinfan61
    Dan
    2007 SR5 Tacoma
