Howling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ringonelso, Dec 31, 2016.
  1. Dec 31, 2016 at 5:25 PM
    Ringonelso
    Ringonelso [OP] New Member
    Just bought a 2017 Tacoma. Noticed howling in rear area immediately. Suspect rear differential. Howling noticeable between 30 and 50 mph. Checked all sorts of things to eliminate air noise and tire noise, not either of these.
  2. Dec 31, 2016 at 6:17 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    BrokenMech, BGXtobe and chuck1986 like this.
  3. Dec 31, 2016 at 6:40 PM
    backtrack2015
    backtrack2015 Well-Known Member
    Austin TX
    2016 Silver DCSB OR 4x4 AT Tech (sold 8/17)
    Pop-n-lock tailgate. New radio knobs. Rear step.
    The loudest noise on mine by far was the lower control arms whistling (search if interested). You might tape those holes up and see if that resolves your howl. If it does help, Toyota has a TSB for this and installs some rubber plugs. I'm still running with my tape (small drain holes punched in the tape).
    EDIT - I only mention the whistling of the LCAs because they were quite loud on my truck and occured at lower speeds like 30 MPH. The rear diff howl is typically not near as loud and seems to be most common in the 50-60 MPH range.
  4. Dec 31, 2016 at 7:24 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Waiting for smitty99 like :popcorn:
  5. Dec 31, 2016 at 7:24 PM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    GPsevinSixx likes this.
  6. Dec 31, 2016 at 7:41 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  7. Dec 31, 2016 at 7:41 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Normal. At 300K get back with us.
  8. Dec 31, 2016 at 11:06 PM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    My Avatar describes how I feel about this
