Hows fluid film do in winter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Oct 14, 2017.
  1. Oct 15, 2017 at 11:06 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I used 6 cans the first time.
    I plan on using only 3-4 cans this year since the insides of the frame are still wet
  2. Oct 15, 2017 at 11:09 AM
    fixnfly
    S.W.PA
    Also, if you remove the plastic bed rail caps, you have plenty of access to the inside of the bed. Especially the wheel well area. Easy to do.
    While the caps are off you can wax the top of the bed rails.
  3. Oct 15, 2017 at 11:10 AM
    DrFunker
    DrFunker Well-Known Member
    :thumbsup: works well for me.
    SilverBulletII likes this.
  4. Oct 15, 2017 at 12:46 PM
    david-oregon2999
    david-oregon2999 Well-Known Member
    Hear, hear! I just soaked the inside of my tailgate with CorrosionX. Corrosion is an affront to Zod (KNEEL!), So I try to keep up with it.
    deanosaurus likes this.
  5. Oct 15, 2017 at 12:49 PM
    david-oregon2999
    Try CRC Heavy Duty Silicone spray on the exhaust. I've got it on everything downstream of the cats, will try it there today.
  6. Oct 15, 2017 at 3:27 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I used clear hi heat paint on my whole exhaust
    igno1tus likes this.
  7. Oct 15, 2017 at 5:11 PM
    david-oregon2999
    Excellent idea!
  8. Oct 15, 2017 at 5:12 PM
    757yotas
    Virginia
    2007 TRD Sport
    Its rustolum from walmart auto section, stops rust and protects up to 2000 degrees. Figured it would work great and is clear so cant even tell its there!
    crhsharks12 and igno1tus like this.
  9. Nov 7, 2018 at 4:31 PM
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    I just purchase a can of Fluid Film. I was wondering if is ok to spray it in the cold? I'm just spraying the whole rear axle. Thanks.
  10. Nov 7, 2018 at 4:43 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Can’t hurt.
    I’ve done my yearly spray of the whole undercarriage as late as the middle of this month.
    Tig3r_Bit likes this.
  11. Nov 7, 2018 at 4:47 PM
    Tig3r_Bit
    2018 TRD OR 4x4
  12. Nov 8, 2018 at 4:07 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I love FF and have used it for years. That said, I think you may be somewhat disappointed in the protection it offers on something like your rear axle - particularly the front side of it. The problem is that FF - even after it "cures" - is still very soft. That means that in applications where there is road spray hitting it on a regular basis, it'll wear off pretty quickly. And since the front side of your rear axle gets blasted pretty well ... The back side of your rear axle will probably fare much better.
  13. Nov 4, 2020 at 2:38 PM
    crhsharks12
    crhsharks12 Well-Known Member
    Denver, CO
    ‘06 Tacoma 4WD TRD Sport DCSB 4.0L V6
    RR 2.5 King shocks front/rear, Camburg UCA's, Icon AAL Springs Softopper & BA Bumper
    why is that?
  14. Nov 4, 2020 at 2:39 PM
    crhsharks12
    Denver, CO
    this is the problem i found with FF. it attracts faaaar too much dirt and gunk. my frame now looks like theres a layer of sludge covering it from all the dust and FF.
  15. Nov 4, 2020 at 4:43 PM
    #35
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    It is better than rust.
    I'm using Woolwax this year--thicker than Fluid Film and just as messy. I sprayed my truck last week-it is still burning off the exhaust.
  16. Nov 4, 2020 at 4:46 PM
    #36
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    @Unchained 5150 does his every year if I remember correctly and his frame looks brand new fwiw.
  17. Nov 4, 2020 at 4:55 PM
    #37
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Yes it does
  18. Nov 5, 2020 at 4:56 PM
    #38
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    That looks nice enough to eat off . So what do you use to clean it with ? You pressure wash it for summer and then FF it in the fall ?
    crhsharks12 likes this.
  19. Nov 5, 2020 at 4:59 PM
    #39
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Honestly I never touch it
  20. Nov 5, 2020 at 5:21 PM
    #40
    igno1tus
    Lol do you drive it once a month ?
