Hows fluid film do in winter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Oct 14, 2017.
  1. Nov 5, 2020 at 5:24 PM
    #41
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Daily driver it doesn't look shiny like that now as there is years of fluid film or woolwax.
    SilverBulletII likes this.
  2. Nov 5, 2020 at 5:51 PM
    #42
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    Here is a sample pic of Fluid Film in action.
    I get it reapplied every year.
    That's not rust near the driveshaft , its Red & Tacky grease
    2013 Tacoma Access Cab TRD 4x4 .
    Dealer passed inspection and was impressed with the condition of the frame that he called all of the techs over to show it off.
    Will continue to use FF? Hell yes!
    TOMB
    Kolter45, ABNFDC and SilverBulletII like this.
  3. Nov 5, 2020 at 5:55 PM
    #43
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Mine goes in tomorrow for the Frame Check. I am sure I will get the same effect.
    TOMB likes this.
  4. Nov 5, 2020 at 6:08 PM
    #44
    ICECOLDBEER
    ICECOLDBEER Well-Known Member
    2006 Tacoma 2.7L SR5
    I'm going to try fluid film this year. Got an undercoating gun that hooks to compressor and picked up a gallon of it for $70 Canadian. I tried it in a few spots. It goes on nice and thick. I like that it didn't drip on to the floor either.
    I used Krown last year paid them to do it. Certain areas you can see it has washed off. I may try something else in those areas that may stick better. I was thinking chainsaw bar oil. I'll probably touch it up again in the spring.
  5. Nov 6, 2020 at 4:47 AM
    #45
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Oh ok , I have mine done also and it’s dirty from road grime and junk . It’s rust free and still shines under the fluid film . It’s a mess to work on but agin rust free (I had my frame replaced in the recall). Next spring I wants clean it all off and in the fall use wool wax . The fluid film I have on it now is holding up great thou I must say .
  6. Nov 6, 2020 at 4:48 AM
    #46
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Actually switched over to Woolwax, zero smell and easier to work with.
  7. Nov 6, 2020 at 4:49 AM
    #47
    igno1tus
    Is it a lot “thicker” ?
  8. Nov 6, 2020 at 4:51 AM
    #48
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I wouldn't say thicker. @jpereira2 what would say is the biggest difference from Fluid Film to Woolwax?
  9. Nov 6, 2020 at 5:11 AM
    #49
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Fluid Film isn't supposed to dry or cure. It's just wax with a thickener so it'll ooze when it gets warm, thicken when it's cold and wash off with spray. It's a gooey mess and around here it with all the dust the under side of my truck is filthy. But I'm not driving a show car.
    I just keep spraying more on over the dirt and dust which builds up a layer that seems to cushion pebbles and rocks blasting the forward surfaces, at least for a while. Fluid Film and Woolwax sell formulations that are very thick, like a grease, that you can use on high wear spots. I use it on the front of the cab mount, for example. It can't be sprayed like the regular stuff so just smear some on.
  10. Nov 6, 2020 at 5:40 AM
    #50
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    Woolwax has almost no smell compared to the fluid film. Thats the biggest difference ive noticed other than you can get the woolwax in a black color.
  11. Nov 6, 2020 at 7:18 AM
    #51
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Definitely thicker doesn't wash off as easily
  12. Nov 6, 2020 at 8:03 AM
    #52
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I used wool wax for the first time this fall after using FF for 5 yrs. No overspray is a big plus with wool wax. I will always use wool wax now. I apply it with a compressor and undercoating gun. Great stuff!
    jpereira2, SilverBulletII and ABNFDC like this.
  13. Nov 6, 2020 at 8:05 AM
    #53
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    I wouldn't say "zero" smell, but definitely less than Fluid Film. I'm still smelling it a week after applying. Nothing crazy though, and I bet it is still burning off some of the warmer areas.
    I picked up this kit from them, works like a charm with a cheap 6 gallon harbor freight compressor. I didn't realize until after I was done, that I should have increased the pressure a bit for the wands inside the frame, but I still think I got good coverage.
    https://www.kellsportproducts.com/W...arts-PRO-GUN-with-2-Extension-wands_p_67.html
    I still have some Fluid Film in spray cans that I use for under the hood, inside the doors, inside the tailgate, and will use it on my snowblower too. Easy to pick up Fluid Film at any of the big box stores.
    jpereira2, SilverBulletII and spitdog like this.
  14. Nov 6, 2020 at 8:17 AM
    #54
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Thought about getting that myself for touch up etc
    jpereira2 and ABNFDC[QUOTED] like this.
  15. Nov 6, 2020 at 8:49 AM
    #55
    spitdog
    I used to use 80psi with FF, I tried the same pressure with wool wax and it was a little weak! Next yr. I think 90 psi should do it.
  16. Nov 6, 2020 at 8:50 AM
    #56
    ABNFDC
    Granite State
    It's a pretty good kit. The bottles are right sized for the gun and it comes with great instructions. I soaked the bottles in warm water to help it flow better.
  17. Nov 6, 2020 at 8:52 AM
    #57
    ABNFDC
    Granite State
    I left it on 100, and it was great with the gun. Will probably bump to 110 next year when using the wands inside the frame.
    spitdog[QUOTED] likes this.
  18. Nov 6, 2020 at 8:56 AM
    #58
    spitdog
    Well, I’ll do 100 then. thanks
  19. Nov 6, 2020 at 9:12 AM
    #59
    ABNFDC
    Granite State
    For those of you with skid plates, I highly recommend you drop them and spray under them, and then spray the skid plates themselves(at least the steal ones-not the aluminum one). There are a couple of places under the skids that collect rocks/dirt and obviously rust. I found that out over the summer when I painted my skid plates--remembered it when I sprayed the woolwax.
    igno1tus likes this.
  20. Nov 6, 2020 at 9:22 AM
    #60
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Doing my rig with WoolWax tomorrow. Dropped the spare last night and went at the hitch area to get an idea of what I may need for the whole job. I made a mistake right out of the gate and bought the cans. Comes with a small 360 wand etc, so it'll get it done, but should have gone for the air kit. That will be the plan going forward. The application was easy though, and looks great initially.
    The plan is to put the truck on stands and remove the wheels tonight. blast inside the rails and all over with compressed air to remove debris, spay it down with the pressure washer, and let it dry overnight. Then in the AM, attack it.
    in regards to the thread title, seems it's just two different ways to skin the same cat. Done right, there's no doubt in my mind it's 100% worth the trouble.
    spitdog and SilverBulletII like this.
