How's my rust look? 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Psychosis, Jun 2, 2023.
  1. Jun 2, 2023 at 7:41 AM
    Psychosis
    Psychosis [OP] New Member
  2. Jun 2, 2023 at 7:43 AM
    Psychosis
    Looks fine to me, just surface rust but wanted to get some other opinions.
    Definitely less than a lot of others I've seen posted.
    Should I take a wire brush to it?
  3. Jun 2, 2023 at 8:01 AM
    lbregman
    lbregman Well-Known Member
    Northern California
    2013 Tacoma ACORMT
    Looks good! Where do you live? If that same rate continues (although it might be exponential) I think the frame would last longer than multiple engines. I do see a crack forming in your crossmember on the 3rd photo, though.
  4. Jun 2, 2023 at 8:07 AM
    Psychosis
    Oh, I see what you mean. Good catch.
    I live in NC, but the truck spent most it's life in Texas and Louisiana.
    Gonna see what I can get off with a wire brush, and get some fluid film on it.
  5. Jun 2, 2023 at 8:27 AM
    lbregman
    Northern California
    2013 Tacoma ACORMT
    Yeah, good idea! It will accelerate in NC I think. Seems like the move is to scrape, wire wheel, degrease, primer, paint/POR 15 and regular “fluid filming”.
  6. Jun 2, 2023 at 8:28 AM
    Psychosis
    Sounds like a plan. I appreciate the advice, thanks!
  7. Jun 2, 2023 at 10:00 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    That’s mostly just weld rust. Pretty common. If you want just wire wheel those areas to remove the flake, then rattle can your choice of black, let it cure for a few days then top coat with a rust protectant if you want. if you don’t see much salt in your part of NC the topcoat rust protectant not even really necessary.
    winkel likes this.
  8. Jun 2, 2023 at 10:23 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    On the inside of the frame by the cats is where you want to keep an eye on.
    You’ll see some holes in the frame, spray inside the holes. They’re like 2 layers in there. So use a spray with a straw to get in there good. This area and the rear close to the shock mounts are the ones that rust out first. And the hitch, if you have the tow package.
    winkel and Just_A_Guy like this.
  9. Jun 2, 2023 at 10:28 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    I’ve seen 3 year old Northeast trucks look significantly worse than that. One rough winter with lots of salt, no car washes, and the frame could look like that.
    MSgt O and TnShooter like this.
  10. Jun 2, 2023 at 10:36 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Second this. Don't waste any time thinking about it, get a rust preventative on it or find a place that does it.
    I replaced my rear bumper and hitch assembly with an aftermarket one that I had galvanized.
    TnShooter[QUOTED] likes this.
  11. Jun 2, 2023 at 11:16 AM
    Paasta
    Paasta Member
    2010 Taco TRD offroad
    Primer?
    I'm researching this atm as well, looking like por 15 offers a full kit with degreaser, metal prep, and paint. I think por 15 top coat is meant to go directly on metal, but...
    Edit: their top coat goes over the rust-prevent coat. they sell primer too, but in the end I don't think it helps anything besides maybe finish.
  12. Jun 2, 2023 at 12:15 PM
    JdevTac
    Josh
    MD/GA
    2nd gen
    You are correct. POR15 doesn’t utilize primer. Straight over etched bare metal or rusted metal as their directions specify. It’s a horrible product for an otherwise clean frame anyway since longevity of adhesion to surrounding intact frame coat will be questionable.
  13. Jun 2, 2023 at 4:55 PM
    lbregman
    Northern California
    2013 Tacoma ACORMT
    Yep, didn’t mean primer for POR15. Good on ya for doing your research. If you’re just gonna paint it with rustoleum or the like, I always like to primer it if for nothing else than another layer of paint..
  14. Jun 2, 2023 at 5:04 PM
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    Looks like surface rust but now is a good time to get on top of it. Brush on eastwood rust encapsulator to stop it in its tracks and then spray woolwax inside/outside of the frame each fall. Will last forever that way.
  15. Jun 5, 2023 at 11:22 PM
    Paasta
    Paasta Member
    OP just wondering what you ended up doing (if anything yet).
    I've had no time to do any more research but if im going to the effort of crawling around and wire wheeling rust, i'm going to do it as best as I can with the best products I can afford.
    The outside of the frame rails seems easy enough, but i'm still not sure how to tackle the hard to reach places like overlapping body panels, inside of frame, etc. Thinking of applying a sealer, but I don't want to trap moisture or accelerate rust either.
