How's the A/C in the quad cabs?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taco1976, Sep 9, 2019.
  1. Sep 10, 2019 at 8:23 AM
    #61
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Just so you know... There are no vents in the rear of the Double Cab (Quad Cab as you called it). There are floor vents that blow under the seats but no vents which blow directly into the back seat area. That said, the front seat area cools down nicely.
  2. Sep 10, 2019 at 8:27 AM
    #62
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    regular cab ac is ridiculous, the double cabs ive been in were good as well, but not as much
  3. Sep 10, 2019 at 8:29 AM
    #63
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    The AC works great but also seems to take a minute or two longer to get cold than my previous vehicles. I read somewhere else in the forum that the delay in cooling was a side effect of the smaller and more efficient AC system that uses less refrigerant. If that is an issue to you then I'd recommend adding remote start so you can start the car (w/AC on) and have it cooled down quicker. Enjoy!
  4. Sep 10, 2019 at 8:48 AM
    #64
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Hah I agree, and MN in late January when we have a week straight at -10 F! Though I haven't had any problems with heat or a/c, so I think they did good on the Tacoma, at least with the dual zone climate control that mine has. I'd assume the regular system is good as well.
    I always say they should force the designers and engineers to work on the cars when they are making them. At least do regular maintenance stuff on them like oil change and tune up. If they think having to nearly pull the engine out to change some spark plugs is a going to cut it... back to the drawing board! I can't believe some of they stuff that gets greenlit like that. Maybe the manufacturer figures it is good for getting those maintenance $$$ in after-sales service...
  5. Sep 10, 2019 at 9:52 AM
    #65
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    It’s hot where I live. I don’t use mine much, unless I have a passenger with me. I usually drive with the windows down. I used to think it was fine until I rode in my wife’s 18 Camry. That AC is ridiculous cold.
    Edit. The AC is about my only complaint I have with the truck. It’s tolerable but that is about it.
  6. Sep 10, 2019 at 1:53 PM
    #66
    Sungod
    Sungod Well-Known Member
    St Augustine
    Windows tinted like all cars in Fla seem to be. Had them check the AC during an oil change and got the "it is normal" response. Pretty much the same response about the transmission so not really shocked.
  7. Sep 10, 2019 at 7:27 PM
    #67
    PuntaGunta
    PuntaGunta Member
    2018 TRD Off-Road
    It’s seems settled that ac works well when moving. The 3rd gen has a factory known problem of not cooling well when stationary or slow speeds. This condition may not be common for most people but if you live in a hot climate like me and have to idle the truck for lunch break or waiting outside for an errand to be done be aware that ac will barely be able to keep up on max blast. Once you start moving again it’s ice cold.
    So for OP’s concerns of cooling a baby. I’d advise get tsb done when new if in Hot climate or get a different truck. No good to have baby idling outside in hot truck.
