Hows the reliability of your 3rd gen holding up?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PanzerDivisionBlack, Jun 14, 2023.
  1. Jun 14, 2023 at 7:06 PM
    #41
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    22's still have this issue? WTF, why can't they do it right! just had mine replaced on my 16. thinking about getting a 23 but if these same things still exist maybe not, i thought all that had been corrected. might go in a different direction.
  2. Jun 14, 2023 at 7:09 PM
    #42
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    2016 SR5 - 120k miles.
    Other than oil changes(engine, differentials, transmission, transfer case) spark plugs and air filters I had to replace the following:
    Battery went out at ~7k miles
    Battery terminals at ~110k miles
    Replaced both CV axle boots at ~90k miles
    Replaced HU at ~110k miles
    Stevie17 likes this.
  3. Jun 14, 2023 at 7:13 PM
    #43
    cgolf
    cgolf Well-Known Member
    2020 Tacoma TRD Off Road
    None
    2020 4x4 OR. 25000 miles. Replaced the battery at 24000 but only because it was original & 4 years old. Never any issues with starting. Just being cautious. No other issues so far.
    Stevie17 and WilliamJames like this.
  4. Jun 14, 2023 at 7:18 PM
    #44
    Bigmatt503
    Bigmatt503 Well-Known Member
    My 2021 sport 4x4 has 37k miles on it and no issues. I've been tuned since 10k miles,
  5. Jun 14, 2023 at 7:22 PM
    #45
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    2020 2.7l 29000 and so far I've done oil changes, tire rotations, refilled washer fluid, and changed the air filters. I do need an alignment, but that one is on me.
    Stevie17, WilliamJames and Gfenza89 like this.
  6. Jun 14, 2023 at 7:45 PM
    #46
    EW///
    EW/// Member
    2021 Super White TRD OR DCSB
    my 2021 V6 with 21k miles is rock solid, not a single issue beside changing oil at 5k miles interval and tire rotations.
  7. Jun 14, 2023 at 7:46 PM
    #47
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    23’s still kickin at 8800.00
  8. Jun 14, 2023 at 11:04 PM
    #48
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    '21 here.
    No issues -knock on wood.
    Only 15k miles so far... all fun.
    75% play miles! - Good ratio on quality!
  9. Jun 15, 2023 at 12:10 AM
    #49
    Breakdown
    Breakdown Well-Known Member
    22 off road in ice cap. 15k, lifted it at 2k. No issues, still have to do the child seat inspection recall. Been keeping a close eye on the paint but no issues.
  10. Jun 15, 2023 at 12:27 AM
    #50
    Spadi_5
    Spadi_5 Well-Known Member
    Wisconsin
    2019 DCSB TRD OR
    2019 TRD OR with 60k, only maintenance and a few recalls have been done. Runs great.
  11. Jun 15, 2023 at 1:43 AM
    #51
    guest_707
    guest_707 Well-Known Member
    '22 TRD ORP. Only a year old at the end of the month and 15.5k miles. So far no issues. Bilstein 6112/5160 2" front lift with a 1.5" aal at around 9k miles and some 255/85r16 Wildpeak MT01 tires at 11k which weights about 20 lbs more than stock tires. I don't even know if my needle bearing has gone bad after the lift. If it has, I can't hear or feel it because of the loud ass mud tires. I probably will do uca either as my next mod or after tint because looking at the tires from the front of the truck looks like the left and right tires make a subtle v shape so toe needs adjusting. Maybe the uca will improving steering, it feels lighter and more vague with the MTs compared to stock.
  12. Jun 15, 2023 at 4:00 AM
    #52
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I think the coolant bypass tube thing is pretty rare now. So I don’t think I would let that worry me. As far as other stuff if your buying a 23 I would say it should be pretty reliable by todays standards . If you feel a little uneasy buy a extended warranty that will at least cover you for anything that crops up pretty much. Luckily the Gen 3 Tacoma is still old school . As time goes on all vehicles will be off the charts complicated and reliability on most brands will be sketchy at best .
  13. Jun 15, 2023 at 4:34 AM
    #53
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    ‘19 with 25k mi. Nothing major yet, but I have had some annoyances.
    The stock battery was garbage after only a couple years. Leaked everywhere. Dealership refused to fix.
    Low pressure fuel pump recall.
    The A/C is pretty weak. Dealership: “normal”
    The hood latch is acting up, and won’t consistently pop open the hood. Cleaning the mechanism did not help. I haven’t brought it up with the dealership yet but hopefully they fix it.
  14. Jun 15, 2023 at 4:44 AM
    #54
    PanzerDivisionBlack
    PanzerDivisionBlack [OP] Well-Known Member
    Sucks because I was led to believe that these trucks are bulletproof all around, when it's the drive train that's pretty bullet proof but the rest of the truck might fall apart around you, my 2022 at 10k had peeling paint, passenger rear door creaked like CRAZY. My tailgate was stuck half the time and the dealer said it was normal. My rear bumper and bed and hood were all terribly misaligned. The quality was not there. Hope my 2023 is better since it wasn't built at the height of COVID craziness where they were rushing trucks fast as possible
  15. Jun 15, 2023 at 5:18 AM
    #55
    aozer
    aozer Well-Known Member
    Dallas
    2020 Tacoma TRD OR Cement
    20 OR 4x4 with 30k miles. no issues so far.
  16. Jun 15, 2023 at 5:18 AM
    #56
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    My '22 Limited (with TRD lift installed on day one) will turn a year old next month and so far zero issues; absolutely love the truck. It's my fourth Tacoma since 2012 and definitely my favorite.
  17. Jun 15, 2023 at 5:30 AM
    #57
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'd have to agree on the a/c, it's no better in our prius. Soon as the temps are over 95 degrees, the a/c becomes nearly useless, but I understand toyota has a fix for it if you require it. As far as anything else, my truck has been perfect going on 23k miles, and change.
  18. Jun 15, 2023 at 5:39 AM
    #58
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Just celebrated 2 years of ownership in May for my 2021 Sport AT/DCSB.
    Completed All Toyota Care Scheduled Maintenance
    Extended Warranty Purchased
    20K+ miles
    OTT Tuned
    Several Improvement Upgrades
    I love my lil truck!
    Even though my eldest daughter calls it, obnoxiously over-sized.
  19. Jun 15, 2023 at 6:41 AM
    #59
    Kenstogie
    Kenstogie Well-Known Member
    Ken
    19 SR 2.7 4x4
    I came to see how everyone was doing with their truck but since I'm here....
    .about 50k on a 19 SR 2.7L no issues.... other than the noise it makes after it's off some kind of evap thing as I recall and that has pretty much stopped also..... I'd say my truck actually runs better and quieter than new now....
    I do tend to baby it as I want to get high mileage out of it and with the 2.7 motor it is entirely possible.....
    the 2,7L is fantastically reliable supposedly but also slow as $#!t too. I'm fine with that though, it aint no sports car...
  20. Jun 15, 2023 at 8:32 AM
    #60
    Old Man Tan 4x4
    Old Man Tan 4x4 Well-Known Member
    North East
    2017 TRDOR DCSB 4x4
    About to hit 89k miles. Timing cover resealed at 77k, rear brake light recall done at the same time. All covered under extended warranty. Meticulous about maintenance, 5k OCI. Other than that the thing is tip top. Absolutely love my truck, rattles and vibrates here and there but its a truck and i wheel it almost daily. Best vehicle ive owned so far.
