How's the ride with a Readylift 3"?
Discussion in 'Suspension' started by GRAY GHOST, Mar 15, 2010.
  1. Mar 15, 2010 at 4:20 PM
    GRAY GHOST
    GRAY GHOST [OP] Member
    Upstate SC
    2011 DC-TRD Offroad-4x4
    I don't really go off-road, but want to mount 285/75/16 tires on my '10 DC-TRD Sport. The Readylift seems to afford the clearance on 285s.
    It says the ride is the same as stock, but I dunno. I have the TRD suspension.
    Will the ride change at all?
    Could you do: Bilstein 5100s with the Readylift? How much would that $$ together?
    I've scoured the site, but hadn't really found specific answers to my questions.
    Thanks
  2. Mar 16, 2010 at 8:46 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    I would save up for some ToyTec OME lift kit or Bilstein 5100's set at 2.5" w/ TSB AAL.
  3. Mar 16, 2010 at 5:57 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    the readylift is gonna ride stiff. you will need new uca's to get your alignment in an ideal range. I dont think you can run a top plate spacer with the billies unless you set them at 0. otherwise your uca will hit your coil.
  4. Mar 16, 2010 at 7:06 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    This guy is wrong, dead wrong. It will not ride stiff at all since it is a TOP PLATE SPACER not a PRELOAD SPACER.
  5. Mar 16, 2010 at 7:12 PM
    TacoSupreem
    Hayden
    Kentucky
    ^^^ With the readylift you will lose travel! thus making for a stiff ride. I have owned the readylift stuff and i know from experience! with a 3" spacer he WILL lose uptravel. making for a stiff jarring ride. dont believe all that "it maintains factory ride" hype. Its just not true!thanks
