How's your 2WD 3rd gen in the snow?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HoldFast401, Nov 26, 2017.
  1. Nov 26, 2017 at 7:04 AM
    HoldFast401
    HoldFast401 [OP] Member
    So as the 2018 tacos are starting to arrive in my area, I need to decide on weather to get 4x4 or not. I've had a 4 cylinder 2WD chevy s-10 for years so I know what to expect with a 2wd pickup.
    My real question is about the new (to me at least) automatic transmission setup in the Toyotas, and how much better or worse they are in the snow. I'm used to the old Park-Reverse-Neutral-Drive-3-2-L style. When I was at the dealership I noticed every car, truck and SUV all have Park-Reverse-Neutral-Drive, and then the shift on the fly feature.
    Is it any help when your spinning the wheels to shift up to the next gear so you're getting less RPM's? In my old truck it at least helps some to shift from drive to 3 to get going at the red light.
    Thanks for any help!
  2. Nov 26, 2017 at 8:06 AM
    Horsethief
    Horsethief Well-Known Member
    Are you planning on keeping this truck forever? If so, this doesn't matter. If not, and you're in an area where you get enough snow to be wondering about getting 4WD, I'm willing to wager that 2wd is going to have crap resale value compared to a 4wd. When I'm looking at Tacos online, whenever I see one that looks to be a really good price, it's because it's a 2wd. I then click to the next ad, because nope, I don't want a 2wd truck.
    I think, and I may be wrong since I do not yet own a Tacoma, the differences in shifter positions are pretty standard now. In the old style 4 speed autos, you had D (or D with a box around it if you had a GM product)which was drive, which allowed you to go through all 3 gears and into 4th which was the Overdrive gear. Then you typically had an "OD OFF" Button (or simply a "D" with no box position in a GM), which would hold you to 3rd gear. Then you had "2" and "1", which would hold you to first and second gears. Sometimes they were called "Low 1" and "Low 2", in reference to being the lower gears in the tranny. My 73 Chevy K10, with a 3 speed auto, had Drive, Low 2, and Low 1 on the column, for an example.
    My Volvo with a 5 speed auto has Park, Reverse, neutral, drive. Then, when in drive, if you nudge the shifter to the left you can then toggle it up or down to change gears manually. So, me nudging it over and shifting down into 2 would be the same as selecting "2" on the older style tranny. I think this is a tad more cumbersome than with the old style, but that's just not practical anymore with transmissions going up to ten gears and beyond now. It works fine the way it is now, I find the manumatic feature helpful in the mountains so I'm not riding the brakes all the way down steep grades. I don't need to use it in the snow to get going though; it's AWD so I just pretty much just stomp and steer.
    On, and your point about shifting up while spinning wheels to get less RPM... well, it may drop your engine RPM down, but your spinning wheels speed will probably go up.
    Honestly though, if you're springing for a BRAND NEW truck, just spring a bit more for the 4wd. You won't regret it. "Man, I really wish I'd gotten the 2wd so I'd be stuck in the snow right now" said NO ONE EVER.
  3. Nov 26, 2017 at 8:36 AM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Amen to the previous poster on the diminished value --Just look at this guy --notice how long he has had his for sale-- more than a year.
    https://www.tacomaworld.com/threads/2017-tacoma-sr5.461748/
    Although It is a nice looking truck, if you are in his area --and it looks like he has taken great care of it!
  4. Nov 26, 2017 at 8:41 AM
    Bishop84
    Bishop84 Well-Known Member
    I had studded tires and weight on my 16 4x4 and still didnt enjoy driving on snow in 2WD. It's fine on groomed roads.
    They suck, too light, but S10's are terrible too. Wouldnt you want to be able to flick a switch and rocket away from a green light?
  5. Nov 26, 2017 at 9:06 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    I live in Phoenix AZ now so 2WD is fine, I'm confident that my chances of seeing snow are... minimal. :rofl:
    However when I bought my 3rd gen, I lived in Pennsylvania, and my 4x2 handled snow just fine. Not as good as 4x4 obviously, but acceptably well with the right tires.
    Hell, I even managed to back out and over a large iced-up snow drift that I was too lazy to clear before it iced up. Auto LSD button FTW.:p
    I would say it boils down to this: if your area gets snow, how often? If we're talking "we might have 2 or 3 snow days in a given year" it's less of a concern.
    And regarding your shifting question, the traction control systems (Auto LSD and so on) are going to be more helpful than shifting the transmission, for the most part.
  6. Nov 26, 2017 at 9:16 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    I've gone through I-70 in Colorado in 2WD. It did fine. Only one part where the ground was slippery.
    No 4WD will ever get you out of that. The big rid in font of me was sliding diagonally to the side, then we both caught traction.
    I live in Southern California where we see 1" of snow every 5 years.
    If you see snow every year, get yourself a 4x4, buy another set of
    wheels with proper snow tires. If you don't buy another set of wheels
    and hit another car, that 1k deductible could have been spent on
    those wheels that I'm talking about.
    Edit: I had OEM tires when I slipped too. (Toyo A30s, all season/highway tire)
  7. Nov 26, 2017 at 9:22 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    4x4 and also for resale...
  8. Nov 27, 2017 at 7:09 AM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    We didn't get much snow last year, but when we did I could barely get out of my neighborhood in 2wd. If you buy some decent snow tires you *might* be ok, but I'll pay the extra money for 4x4 for piece of mind alone. Nothing more embarrassing than being the "truck" guy and getting stuck.
  9. Nov 27, 2017 at 7:19 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    The only way I know of to be able to actually start in a taller gear than 1st is with a manual trans.
    And this is actually a good feature to be able to use on the slick stuff. Even slipping the clutch a bit works wonders on the slickery.
    shakerhood likes this.
  10. Nov 27, 2017 at 8:44 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    A 2WD truck is going to do like any other 2WD rear wheel drive truck does. It will suck in the snow. Put on good winter tires and some weight in the back will cause it to suck less. Gearing won't affect it as much as good tires and weight. It is what it is.
  11. Nov 27, 2017 at 8:57 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    also you could probably safely air down a bit in snow since youre not going to be going as fast, that could help especially in the rear with losing traction during takeoffs... Other than that as others have said get good tires, and try to conserve speed on snow versus speeding up and slowing down a lot. Try to coast whenever you can instead of fully stopping and that sort of thing. If your tire and wheel are sized right you should be able to go down to 10-15 psi easily on snow without worrying about popping a bead unless youre hooning
  12. Nov 27, 2017 at 9:15 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    Shifting the Tacoma auto into s2 or s3 won’t help as it only limits how high it will shift, it always starts in 1st.
    HoldFast401[OP] likes this.
  13. Nov 27, 2017 at 9:38 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Thats where not putting the Truck in ECT mode helps.
  14. Nov 27, 2017 at 11:03 AM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    I fail to see what ECT mode has to with my statement. When I had my 16, all the S mode did was limit the max gear, ECT or not.
  15. Nov 27, 2017 at 11:52 AM
    Herniator
    Edmonton
    There is a lot of people who as soon as they start there Truck put it into ECT mode. By not putting it into ECT mode when it's slippery helps maintain traction. Some vehicles have a snow button which will start the vehicle in 2nd and make the throttle response lazier in order to keep traction.
  16. Nov 27, 2017 at 12:36 PM
    Whale 638
    Whale 638 Active Member
    2018 DC Long bed 4x4 SR5
    I have had three Tacomas. My first was a 2wd access cab with the 4 cyl engine. With weight in the back it did much better than my double cabs in 2wd. That said, it wasn't very good in the snow. I did get book value for it when I bought my first DCLB. I work for the power company and am always driving into work in blizzards. A 2wd would leave me stuck.
  17. Nov 27, 2017 at 2:07 PM
    Dirty Harry
    Andrew
    SW Florida
    I'm pretty sure it will upshift on command. You may have to start spinning the wheels first.
  18. Nov 27, 2017 at 2:19 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    I never could get it to shift on command, but that might do it. I traded it for 17 with the MT so now its always in the gear I want.
  19. Nov 27, 2017 at 2:21 PM
    Dirty Harry
    Andrew
    SW Florida
    Ah, that'll do it. haha
  20. Nov 27, 2017 at 3:46 PM
    HoldFast401
    Thanks for all the input, I plan on owning the truck forever like my chevy, but the extra resale value is something I wasn't even thinking about. One more reason the the 4x4. Seems and extra 3K MSRP option on the 2018's
    I live in Rhode Island, where during winter we often get snow, then rain as it warms up during the day, then it all freezes up at night. (reason for the 4x4)
    Not usually big amount of snow, and when we do get hit the governor basically shuts down the state and urges everyone to stay at home. In the 18 years I've been driving the chevy I only got stuck once, and that was trying to pass a semi that was stuck. OTOH, there's been plenty of times that I had to fishtail my way to into work. One day I swear with I must've put an extra mile or two on my 20 mile commute.
    I married my tacoma likes this.
