hows your clutch in the cold?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brich999, Dec 10, 2016.
  1. Dec 10, 2016 at 5:14 AM
    brich999
    brich999 [OP] Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    its that time of year again where temps drop and i complain more. 12 degrees this morning when i left for work. clutch barely works around those temps. after releasing the clutch it takes a good few seconds to engage. very stiff and just generally unhappy working in sub freezing temps. anyone else having issues? know im not in the coldest part of the world, and know it only gets worse as temps go lower. is there a good solution for this? i was thinking a colder rated clutch fluid maybe? never had this issue in my other MT equipped cars but my last rx8 breathed fire and always got a decent warm up so everything got hot quickly
  2. Dec 10, 2016 at 5:17 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    G2s did this too. After a minute or so it quickly goes away.
  3. Dec 10, 2016 at 6:06 AM
    brich999
    Bryan
    all tore up already
    after 25 min and 20 miles mine was still slow. but not quite as bad as it was at first. what i notice is just warming up the truck idling doesnt seem to help much
    Bombagee likes this.
  4. Dec 10, 2016 at 6:10 AM
    Plain Jane Taco
    USA
    Mine always rebounded quickly once I started driving. Idling never did much
  5. Dec 10, 2016 at 6:48 AM
    ievko82
    ievko82 Well-Known Member
    WV
    17 sport DCSB quicksand
    Same here. Seems like as the truck get more miles on it the pedal starts to loosen up quicker.
  6. Dec 10, 2016 at 10:05 AM
    livingfreeyyc
    livingfreeyyc Well-Known Member
    Cory
    16TRD offroad ac mt
    Toytec boss with aal in the rear 265 75 16 inch tired roof top tent
    -20 here and clutchs works but can definatley feel its cold!
    Teton Tacoma likes this.
  7. Dec 10, 2016 at 11:52 AM
    pjensen641
    pjensen641 Well-Known Member
    Boone, IA
    '17 MGM ACLB Sport Manual
    If it takes "a good few seconds" to engage, take it to the dealer. Not normal. I have my doubts about this statement.
    Every vehicle I have ever owned has stiffer brakes an clutch in the winter. letting it idle isnt doing a damn thing. The brake lines are not hooked to the engines cooling system in any way, so warming the engine has nothing to offer. Once you start moving, hot air from the engine and radiator will flow back and help some.
    You either need a heated garage or just have to deal with it. Only other thing to try is placing an incadecent light bulb under the hood near the master cylinders or under the transmission near the slave cylinder. Might help a little, but dont get it too close to melt plastic bits. It's surprising how much a 75 watt bulb can do.
    All fluids get stiffer in the cold, just physics. You could try swapping to a lower viscosity fluid, but that requires flushing the old out, and making sure its compatible with the brake and clutch system.
  8. Dec 10, 2016 at 1:13 PM
    MGCPNGN7
    MGCPNGN7 Well-Known Member
    2016 5spd 4x4 2.7L
    Feels fantastic, wouldn't change a thing...
    Because I bought the 2.7 5spd.
  9. Dec 10, 2016 at 2:00 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    It's hella cold in CA right now, like 55*, clutch is performing flawless.
    Can you add engine block heaters to these? or just let the truck warm up longer.
  10. Dec 10, 2016 at 2:27 PM
    thdrduck
    thdrduck Well-Known Member
    Live in the midwest, this morning it was 4 deg when I left for work and everything was fine. I have never had a clutch that didn't work right when it was cold but transmissions that are stiff at first and hard to shift when cold are the norm. Letting it warm up some seems to loosen the trans and it will shift easier but I don't think it will have any effect on the clutch. I think you have other issues.
  11. Dec 10, 2016 at 2:57 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    On my 08 Tacoma the Brake and Clutch Reservoir were shared and the cold did not bother it much, my 15 has 2 different Reservoirs with the Clutch sitting out by the fender and the pedal does react slower than my old 08 in the cold.
  12. Dec 10, 2016 at 4:09 PM
    pjensen641
    Boone, IA
    Yes, you can add a block heater. I just did about an hour ago. It's a cartridge style that fits in to a machined hole in the block. no draining of the coolant.
    Normally I would say that it wouldn't to a damn thing for the clutch, but the clutch line runs very close to the block and heater on the drivers side rear of the engine. It might radiate a small amount of heat to the clutch line.
  13. Dec 10, 2016 at 5:37 PM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Here you go. some good discussion here on the lack of cold weather performance.
    https://www.tacomaworld.com/threads/cold-weather-performance-or-the-lack-thereof.408322/
  14. Dec 10, 2016 at 5:48 PM
    Clearwater Bill
    Billy
    Largo Florida
    Put some water line wrap on the clutch line and plug it in when home.
    And there is no 'clutch fluid'. It's brake fluid.
    Brake fluids are rated for boiling points and water absorption, but don't recall seeing anything about cold viscosity.
  15. Dec 10, 2016 at 7:42 PM
    livingfreeyyc
    Cory
    16TRD offroad ac mt
    I wish it was 55 degrees here but that aint gonna happen currently -20 plus wind chill of -35 so umm I don't recommend a block heater for that temp. It would be a wast of your money cause you would cook it!
