hows your rear end after your lift
Discussion in 'Suspension' started by Jrobertson, Jun 22, 2016.
  1. Jun 22, 2016 at 6:30 AM
    Jrobertson
    Jrobertson [OP] Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    So, long story short, i bought a fox supension - loving it so far. I have the 2.5 with resi up front. and the 2.0 with resi in the rear. i paried the setup with an icon progressive aal and some new UCA.
    The question i have is when i go over some bumps, say a speed bump around 45mph the front absorbs it up. but the rear almost "hops" over it. I don't know what it should feel like, and while its a lot better then stock i just wonder how your feels. does it feel like.
    Im wondering if the lack of weight in the bed just causes it to jump a little. its not actually leaving the ground or anything. i just feel the shocks push the rear up as it leaves the hump if that makes any sense.
    do you think the progressive AAL needs some time to settle a bit? only been on and driven 50 miles or so.
    YotaDan likes this.
  2. Jun 22, 2016 at 9:08 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Most likely is the lack of weight in the back end not forcing the spring pack to work properly. Throw about 150lbs or so in the back (strapped down preferably), and try the same speed bump.
  3. Jun 22, 2016 at 9:56 AM
    Jrobertson
    James
    Stock. For now.
    Will do thank you.
    YotaDan[QUOTED] likes this.
