HP Mods - Time Performance gains
Discussion in 'Performance and Tuning' started by wiscdave, Sep 25, 2008.
  1. Sep 25, 2008 at 12:55 PM
    wiscdave
    wiscdave [OP] Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    4.0l is 0-60 in 7.5 seconds according to Motor Trend The 1/4 mile times differ with altitude, humidity etc so when stating your numbers please include location of your "track"
    But overall:
    What are the actual numbers out there you guys are running?
    Intakes have produced gains, any ideas of some true numbers in reducing 1/4 and 0-60 times. URD with calibration sounds like the best product on the market but who has the timeslip.
    Exhausts again will produce gains, any ideas of some true numbers.
    Intake/Exhaust combos that work well - Which Y -pipe is best
    Please do not let this turn into an anti- racing thread. If you want to comment on that please start your own thread. thanks in advance
  2. Sep 25, 2008 at 1:03 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    when I went to the track, I got a 6.85 second time with my URD intake installed. This was in pretty cool weather though.
    I added on the URD MAF calibrator and I finally tested it again and it took 7.65 sec. Maybe my wires aren't correct, or maybe the 50 degree temperature difference is causing the problems.
  3. Sep 26, 2008 at 6:27 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Wow quite a difference, what did you run the 1/8 or the 1/4 and times?
  4. Sep 26, 2008 at 4:40 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    My last 1/4 time slip. 13.99 @ 101. DA = 2614'. End of June in San Antonio, TX. 0-60mph is an estimated 5.2 seconds (based on 1/8 mile pass).
    I'm getting to run the truck again, and hope to come close to the 12 second mark.
  5. Sep 26, 2008 at 4:45 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I have a dashhawk that I use on an empty track that measures 0-60 times. It's not entirely accurate though.
