HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 24, 2020 at 1:10 PM
    #6941
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, you will lose some engine monitoring functions.
  2. Sep 24, 2020 at 1:24 PM
    #6942
    aboftofbeam
    aboftofbeam Well-Known Member
    Karl
    San Diego, CA
    2012 Taco Off Road DBCB
    S/C, UCON, 2.8 pulley, bedrug, Crashnburn's ultimate headlight/tailight upgrade, Moroso oil-catch can, soundproofing, speaker and H/U replacements, bed stiffeners, SHMELLFAB Sliders, ICON AAL.
    Yep, understood, but if his plan was to turn it off and leave it in place, there is some risk there, and if he is still covered under warranty he might as well get the new parts if he converts back...
    That sucks. Just make sure you get the block off plates and don't leave your old system in place.
    jpereira2[QUOTED] likes this.
  3. Sep 24, 2020 at 2:53 PM
    #6943
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Or get 2011 and earlier headers, no block off plates needed :thumbsup:
  4. Sep 24, 2020 at 3:48 PM
    #6944
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  5. Sep 24, 2020 at 3:48 PM
    #6945
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My 14 has an 11 ECU and everything works like it did before.
  6. Sep 25, 2020 at 12:08 AM
    #6946
    zippsub9
    Halfmoon, NY
    14 DCLB
    interesting....I thought @JustDSM was sorting through some commo issues still. Great news!
  7. Sep 25, 2020 at 4:31 AM
    #6947
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I'm confused now....in that for sale post it specifically states he is selling because it does NOT block off the rear air injection port.
    So do the 05-11 headers work on the 12-15 and block off ALL of the ports on the head? Or is it only specific brands that will work?
    I have a 12-15 and would like to add headers at some point when the time is right, that's why I am curious.
  8. Sep 25, 2020 at 6:00 AM
    #6948
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It looks like it’s sale pending. I’m pretty sure it’s the right headers and right side valve cover that differ. Engine block and heads are the same across all the years. software differs, but HP tuners can delete the software part of the secondary air injection system, for off road purposes only. Some people use an older ECU instead so there is no trace of this software change.
    someone else can chime in if I missed something
  9. Sep 25, 2020 at 6:12 AM
    #6949
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don't know if he was, but I read many guys say it doesn't work. I tried it and it works on my truck. I'm sure certain combinations of parts do have issues, but my setup works.
  10. Sep 25, 2020 at 6:17 AM
    #6950
    TacoFergie
    Iowa
    Yes, I believe those are sold. I'm not looking at the current moment.
    But It sounded like in that sale post that It would not cover one of the ports. I already have removed my SAIS because I only use my truck on the track for auotx.....;-) lol
    henryp[QUOTED] likes this.
  11. Sep 25, 2020 at 6:42 AM
    #6951
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    It worked fine on my truck and covered all the ports. My SIA was already removed.
    Not sure if it's a requirement but I removed the stock studs and replaced with shorter arp studs. The hole threads needed to be chased out with a slightly larger tap.
    420taco and TacoFergie[QUOTED] like this.
  12. Sep 25, 2020 at 8:20 AM
    #6952
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    ^^^which headers did you go with? All this time I thought the heads were different, too. Would be great if all years headers bolt up to a SAI deleted truck...hypothetically.
  13. Sep 25, 2020 at 9:09 AM
    #6953
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    2011 cluster is actually like 12-15. 05-10 is different
    TAC1 and zippsub9 like this.
  14. Sep 25, 2020 at 9:14 AM
    #6954
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yes, I bought an 11 cluster too but as it turned out I did not need to install it.
  15. Sep 25, 2020 at 9:57 AM
    #6955
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Older headers will mate up to a deleted sais truck. You just should use the newer style gasket.
    For instance- my 2009 truck has pre 2012 spec-u headers with 2012+ gasket mated to heads from a 2015.
  16. Sep 25, 2020 at 10:11 AM
    #6956
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    Thanks for the v2 @JustDSM and v14 @nd4spdbh tune. Got it loaded, just need to test it out!
    nd4spdbh and JustDSM like this.
  17. Sep 28, 2020 at 9:26 AM
    #6957
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    This may sound like a dumb question, but, if you disconnect the negative battery for more than 10 min, do you have to re-flash your tune?
    TAC1 likes this.
  18. Sep 28, 2020 at 9:27 AM
    #6958
    zippsub9
    Halfmoon, NY
    14 DCLB
    No
    ARoman83[QUOTED] and TAC1 like this.
  19. Sep 28, 2020 at 9:36 AM
    #6959
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    @JustDSM told me the tune stays there permanently. In my case I had sent him my ECU but regardless of the method you got your tune it’s permanent in the ECU.
    ARoman83[QUOTED] likes this.
  20. Sep 28, 2020 at 9:57 AM
    #6960
    ARoman83
    Alex
    Wisco
    Only legal stuff
    Thanks guys! I guess when I start my truck and see flashing lights like x-mas I would of know lol
