HPS Intake Tube and Gibson Cat-Back
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike G, Nov 2, 2020.
  1. Nov 6, 2020 at 5:35 AM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    I've been running the whole HPS set up now for a year, paired with the mbrp cat back exhaust. Zero complaints. I also modified the exhaust to dump after the axle.
    eurowner likes this.
  2. Nov 6, 2020 at 5:57 AM
    Josh-L
    Josh-L Well-Known Member
    2021 Silver SR DCSB V6 4x4
    Any install videos for the HPS tube?
  3. Nov 6, 2020 at 6:10 AM
    NorNev
    Dave
    A Few
    It's pretty straightforward, remove factory tube/resonator- replace with new tube. The whole kit involves more, but that in itself is pretty easy too.
  4. Feb 19, 2021 at 1:01 PM
    xLOGREx
    xLOGREx Well-Known Member
    Logan
    SL,UT
    2017 White SR5
    Little of this, little of that.
    Did you have to trim the HPS tube to fit? I know the CAI guys have to but I haven't heard about the stock intake people.
  5. Feb 20, 2021 at 5:39 AM
    NorNev
    Dave
    A Few
    No. I installed the whole kit. Shouldn’t have to trim anything.
    xLOGREx[QUOTED] likes this.
  6. Feb 20, 2021 at 5:50 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Right on. What are your thoughts on the kit now that you’ve had it for a couple months?
  7. Feb 21, 2021 at 6:37 AM
    NorNev
    Dave
    A Few
    zero issues.
  8. Feb 21, 2021 at 7:49 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I have installed the HPS tube, Green Filter, TRD Intake Flow Accelerator, and TRD Exhaust. I installed the exhaust after 500 miles on the brand new truck. Got the other pieces used off BST, and installed the tube first, then the filter, then the IFA. After each part installed I do notice a difference, though after installing the IFA the induction sound was quieter.
    I live at 7000', drive anywhere from 4000 to over 11000, so every little mod helps as every 1000' elevation change is a 3% HP change.
    xLOGREx likes this.
  9. Feb 21, 2021 at 8:54 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    Great info! I have an AFE pro dry filter and magnaflow muffler (cut in to existing pipes) now and I’ll be installing the IFA tomorrow hopefully if my dealer gets it in. I’ll be doing the intake tube next. Did the intake tube increase noise for you? I live at 4000’ and pretty much stay in that range.
  10. Feb 21, 2021 at 9:18 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Thanks! Yes, the HPS tube allowed more induction noise and the engine does rev smoother/quicker as the intake resonator is gone and the inside of the tube is smooth; the path of least resistance.
  11. Feb 21, 2021 at 9:36 AM
    xLOGREx
    Logan
    SL,UT
    2017 White SR5
    That’s awesome, I can’t wait to have mine done! Thanks!
