Hub adapters and wobble.
Discussion in 'Wheels & Tires' started by 3coma, May 26, 2017.
  1. May 26, 2017 at 3:49 PM
    3coma
    3coma [OP] my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    So I bought new wheels with a 108 bore and all I could find was thin plastic adapters. Anyone bought metal ones and where did you get them? I'm getting a a slight wobble and it's driving me nuts. Yes everything was torqued evenly with lug centric nuts.
  2. May 26, 2017 at 4:02 PM
    angrysam
    angrysam Huh?
    Sam
    Somebody's Shit List
    2.9 Gen- Not a cunt.
    Fleshlight and an old Farrah Fawcett poster.
    I've never had an issue with the plastic ones.
    Are you sure the balance is good?
    Are you sure the wheels are true?
    If you have large rust deposits on the hub mounting surfaces you can get a wobble.
  3. May 26, 2017 at 9:36 PM
    McG
    McG Member
    Ontario
    ‘97 Tacoma SR5
    Levelled on Bilsteins/Tundra coils, 33x12.5 Mickey Thompson MTs.
    Metal hub rings are just little pieces of aluminum that will space your hub to the required size so I leave the idea of quality with you...
    With that said, you can find aluminum hub rings to go from 106mm to 108mm on eBay for a good price on eBay.
    http://m.ebay.com/itm/Hub-Centric-Rings-OD-108-1mm-ID-106-1mm-Aluminium-Alloy-/181530971829
    If you are concerned about the quality of metal or workmanship you can get high quality aluminum hub rings from the lads at Motorsport tech.
    http://www.motorsport-tech.com/hub_rings.html
  4. May 27, 2017 at 6:10 AM
    3coma
    rob
    Thanks McG, I had it aligned a couple weeks ago and did the ecg bushing yesterday which made it much better than before. I guess balancing is next, but they only have about 3k miles on them.
