Hub assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edward25, Dec 6, 2019.
  1. Dec 6, 2019 at 6:02 AM
    Edward25
    Edward25 [OP] Member
    What’s up guys wheel bearing is shot so I’m going to replace my whole hub assembly. What size socket do I need for nut holding down the wheel assembly?
  2. Dec 6, 2019 at 6:13 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    What year is your truck? 4×4, etc?
    This video helped me a ton when I did the bearings on my previous 4runner. I think the parts and process are nearly identical for a 2nd gen Tacoma
    https://youtu.be/BVuM8iVO6u8
  3. Dec 6, 2019 at 6:19 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    35mm socket.
    This guy is the go to around here for pre-assembled hubs with quality bearing:
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-4x4-prerunner-nsk.537080/
    He does great work and is quick. I did mine a few weeks ago, paid Wednesday evening, shipped Thursday, and had parts Saturday. Highly recommend.
    Also one tip that I struggled with is it’s much easier to press the new seal into the spindle if you just pull it off the truck. I fought it for hours on the truck tilting it out but couldn’t get the seal to go on straight. Then I took off the last 2 bolts holding the spindle on and then was able to press the seal in less than 5 min.
  4. Dec 6, 2019 at 6:37 AM
    Edward25
    My truck is 4x4. Also is it difficult to replace the hub assembly?
  5. Dec 6, 2019 at 6:37 AM
    Edward25
    It’s an 07 Toyota Tacoma 4wd
  6. Dec 6, 2019 at 7:40 AM
    Thatbassguy
    James
    Check out the video. I think it has the tools listed.
  7. Dec 6, 2019 at 10:50 AM
    Muddinfun
    Muddinfun Well-Known Member
    The "Toyota master mechanic" is a dumb ass. He bent the shit out of the hard line and left out the O ring.
    whatstcp likes this.
