Hub/Bearing assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davek, Aug 21, 2012.
  1. Aug 21, 2012 at 12:26 PM
    davek
    davek [OP] Member
    Dave
    MD
    08 TRD SPORT 4x4
    Gibson exhaust, wheels and tires
    08 TRD Sport 4x4 DC...dealership said both front hubs/bearings need to be replaced, with labor over 2 grand.....looking aftermarket and they are so much cheaper...I know nothing about this or what to buy. I just want to make sure I get everything I need because the price diff from the dealership is crazy....Any help would be greatly appreciated!
  2. Aug 21, 2012 at 12:28 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Wow! How much for just the hubs? Its really easy to install new hubs yourself. Just needs basic hand tools.
  3. Aug 21, 2012 at 2:33 PM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    2 grand?? Man that sucks. How many miles on your 08? I'd definitely do it myself.
  4. Aug 21, 2012 at 3:50 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Boy I guess I need to get into the business of doing these. I could knock em out quick and charge you a lot less.
    There is a sticky here about em, get the part #s, order through rock auto.
  5. Aug 21, 2012 at 5:05 PM
    chewingonabone
    chewingonabone Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    Just went through the same problem on my 2009 taco. Dealer wanted $1400. I called around to some mechanic shops in the area, they were more reasonable..in the $600 range for both.
  6. Aug 21, 2012 at 5:42 PM
    davek
    davek [OP] Member
    Dave
    MD
    08 TRD SPORT 4x4
    Close to 124,000. I don't have a press so doing it myself is not an option.
  7. Aug 21, 2012 at 5:46 PM
    davek
    davek [OP] Member
    Dave
    MD
    08 TRD SPORT 4x4
    I have a Toyota parts dept hook up which is around $600 for both but it seems aftermarket is much cheaper. I don't know enough about it (brands) to know if they are dependable or not.
  8. Aug 21, 2012 at 5:47 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Here is the basic idea, very very simple to do. You will not need any special service tools and a lot of the steps wont pertain to this job because you will be replacing the know assembly not just the bearings.
  9. Aug 21, 2012 at 5:47 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Sure it is. Remove them and take them to a local NAPA. Mine charged me $20 and were done 2hrs after I dropped them off.
    Shouldn't cost you more then $300 to DIY.
    If I can do it with basic tools a drunken monkey can. Only specialty item you need is the 53mm or whatever it is socket for the hub nut removal.
  10. Aug 21, 2012 at 5:55 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    i recently sent my left front bearing out to get taking care of. the machine shop charged only 20 bucks to remove the old bearing assembly and to press the new bearing on. its the labor that is associated with separating the old bearing from the hub, it sucks ass and has to be cut/ground out from the hub itself. most techs wont deal with that so they will recommend a whole new hub and bearing assembly rather then dealing with separating the old bearing or dealing with the down time of waiting for the machine shop to do their thing and to bring it back.
  11. Aug 21, 2012 at 6:11 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    35 lol
    the ones through rock auto are SKF, decent bearings, just pack em with good grease.
  12. Aug 21, 2012 at 6:12 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Really doesn't take that long to cut it with a grinder and crack it off with a chisel though. Or to press it.
  13. Aug 21, 2012 at 6:14 PM
    MonkeyProof
    SoCal- SGV
    the grinding and chiseling i can do..the pressing no unfortunately
  14. Aug 21, 2012 at 6:16 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Dude, all those snap-on tools and no press?! FOR SHAME
  15. Aug 21, 2012 at 6:18 PM
    MonkeyProof
    SoCal- SGV
    and no welder either:eek:
  16. Aug 21, 2012 at 6:18 PM
    XXXX
    sKiP
    05 Prius
    One of those things I only did twice (one on each side) and hope not to do for another 3 years. I never even bought the socket although I need to. I just borrowed it.
  17. Aug 21, 2012 at 6:19 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Yeah, good trail tool lol.
    Wasn't THAT bad. Setting it up to be pressed is the biggest PITA.
  18. Aug 21, 2012 at 6:23 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Where in MD are you? If you're close, I can do it.
  19. Aug 21, 2012 at 6:24 PM
    XXXX
    sKiP
    05 Prius
    I have been extremely lucky wheeling *knocks on wood*
    I popped a bead on a tire once :D
    I do have my first CV starting to take a crap after 85k :)
  20. Aug 21, 2012 at 6:32 PM
    Blackcat10
    Blackcat10 Well-Known Member
    Word of caution. I have replace a number of wheel bearings using aftermarket (Chinese) and they are a waste of your time and money. Go OE Toyota or Timken bearing. 4x4 is a piece of cake to remove then take and have hub pressed out and into new bearing. Just be carefull and dont pull the inboard cv joint apart.
