Hub bearing part question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eyball, May 13, 2011.
  1. May 13, 2011 at 3:44 AM
    eyball
    eyball [OP] Well-Known Member
    Quinebaug, CT
    05 Double Cab SR5 V6
    Extang Tri-Fecta Tonneau cover, Westin nerf bars, K&N intake, OEM roof rack.
  2. May 13, 2011 at 6:22 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
  3. May 13, 2011 at 6:45 AM
    eyball
    Quinebaug, CT
    thats what I thought. I thought it looked different than the pictures I viewed on here. Thanks!
  4. May 13, 2011 at 8:48 AM
    BlueT
    NorthEast
    So no local shop has presses ? or they dont want to do this?
    I can probably put complete hub together and press them then ship as one part. Are you interested ?
  5. May 13, 2011 at 9:12 AM
    eyball
    Quinebaug, CT
    Well I have been calling around with no luck. I called a NAPA today and they said no but did tell be about a place about 30 minutes away. I called them and he said he might be able to do it. He said he did a 2003 4Runner a few years ago and I said its probably the same. He said $75 as well. I am hoping thats for both side but I forgot to ask. He also is only open during the week so I would have to get out of work which is very hard for me.
    What would be the cost if I had you send it already pressed? I would defenitly be interest. I would have to get new bolts then as well.
    Thanks!
  6. May 13, 2011 at 9:48 AM
    BlueT
    NorthEast
    Ok let me look at where I can get parts, Do you want all Toyota parts or you want me to check Napa atleast for bearing and maybe seal. Or Autozone. ?
    Anybody else interested since I will be looking for parts? not gonna do this twice :D
  7. May 13, 2011 at 9:55 AM
    eyball
    Quinebaug, CT
    I would rather try to keep the costs down but dont want the el-cheapo parts either. I dont care if they are aftermarket though.
    Thanks!!
  8. May 13, 2011 at 4:33 PM
    BlueT
    NorthEast
    Ok so I put down the complete list of parts if somebody wants to replace everythign that supposed to be replaced when doing wheel bearing.
    Description Price per item HUB SUB-ASSY, FRONT AXLE, LH 200.87 BOLT, HUB (FOR FRONT AXLE LH) 4.15 SEAL, OIL (FOR FRONT AXLE HUB LH) 4wd 42.42 NUT (FOR FRONT AXLE SHAFT LH) 4wd 3.91 CAP, FRONT AXLE HUB GREASE, LH 18.66 CAP, FRONT WHEEL ADJUSTING LOCK, LH 3.95 BEARING ASSY, FRONT AXLE W/ABS ROTOR LH 176.14 4x BOLT, W/WASHER 2.17 Front suspension - Brake components - Bearing - O-ring
    O-ring Back - 4 wheel drive 2005 – 2011 4.8 OEM Toyota PIN Cotter 0.83
    So it looks like total cost for a swap parts would be $464.61
    I got Toyota prices from their parts website. I am sure it gets lower in the store itself.
  9. May 13, 2011 at 5:08 PM
    eyball
    Quinebaug, CT
    Ouch! Toyota of Dallas has the hub listed at $146 the bearing at $114 & the seal that goes in between for $10. I don't think I need anything else except maybe the seal that goes behind the knuckle. I heard you could reuse the o-ring. Oh & the 4 bolts if I am having someone else press it for me.
    Local Monroe shop quoted me $419 to do the job but that was $271 for the parts. Probably just bearing & seals.
  10. May 13, 2011 at 5:40 PM
    BlueT
    NorthEast
    I know , i calculated if ordering from Toyota Dallas it would be $330 for parts. (complete)
    And minimum - would be $150 (bearing two seals and O ring) per side .
    Although I am not going with whatever crappy bearings are there originaly so probably gonna cost me $170 per side
    Sounds like Monroe is good deal I would jump on it. Me... I will be doing it myself:D
  11. May 13, 2011 at 6:33 PM
    eyball
    Quinebaug, CT
    So your going with aftermarket bearings fir yours? So do you need a different bear g if you have ABS? I was looking on autoPartswharehouse.com & they have one for like $73 then an ABS one for $130?
  12. May 14, 2011 at 9:49 AM
    eyball
    Quinebaug, CT
    I am getting ready to buy the parts to do my wheel bearing, does anyone know if I need a specific bearing for ABS? I see online there are some that dont say anything about ABS & others that say w/ABS rotor?? I thought all the Tacoma's had ABS? I dont want to buy the wrong part.
    Thanks!
