Hub centering rings?
Discussion in 'Wheels & Tires' started by Fabulous, Oct 26, 2010.
  1. Oct 26, 2010 at 7:47 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    My new wheels came in, and they were supposed to come with centering rings, but weren't in the pkg...guess I'll have call em up. Question is, how many of you use the centering rings on your aftermarket wheels? If no, do you get any vibrations from it. My new wheels have a center bore of 110, and if I'm not mistaken the hub is 108, or 108.6, right?
  2. Oct 27, 2010 at 7:17 AM
    Fabulous
    Fabian
    Calgary, AB
    Hello, is this thing on...
  3. Oct 27, 2010 at 5:43 PM
    Fabulous
    Fabian
    Calgary, AB
    So none of you guys with aftermarket wheels run these rings, or what?!
  4. Oct 27, 2010 at 5:57 PM
    goride
    goride Well-Known Member
    Josh
    UTAH
    22 4dr lb white off-road
    Tint, sliders, puddle pods, on my way to more….
    Are trucks are lug centric not hub centric.:D
  5. Oct 27, 2010 at 5:58 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I left mine in the box
  6. Oct 27, 2010 at 6:32 PM
    Fabulous
    Fabian
    Calgary, AB
  7. Oct 28, 2010 at 6:51 PM
    goride
    Josh
    UTAH
    Interesting because I just got my wheels a couple months ago ordered lug centric because that what my truck calls for, they accidentally sent the hub centric and they did not fit over the hub because they were the hub centric version, they had to be sent back for the lug centric version that were correct.Just my story
  8. Oct 28, 2010 at 7:02 PM
    Namyo
    Namyo -
    pretty sure mine is hub centric.
  9. Oct 29, 2010 at 7:59 AM
    Fabulous
    Fabian
    Calgary, AB
    They were probably hub centric, but the wrong hub size. No worries, I found a place that I can order some from in Vancouver. Mine will be a 106mm to 110mm adaptor.
  10. Oct 29, 2010 at 8:22 AM
    GAmtber23
    GAmtber23 Well-Known Member
    Georgia
    '10 Tacoma Access cab 4x4
    Window tint, debadged, fog-lite anytime mod, aftermarket taillights, low profile toolbox modded with three mountain bike mounts, JVC dvd headunit, Kicker hideaway, Fox 2.5" IFP with DSM UCA's, Allpro standard (soon to be expedition) leaf pack, 255/85r16 BFG KM2's, 1.25" spidertrax wheel spacers, powdercoated gloss black TRD offroad rims with color matched center caps.
    Yes our trucks are Hub Centric. The reason you would need rings if you have a lug centric wheel would to prevent the studs prematurely wearing. When you have the ring, or OEM wheel, the pressure to keep the wheel centered is all on the ring and it also doesn't allow any type of movement. When you run lug centric, the wheel is no longer kept in place by the ring, but the studs themselves. This can cause severe stress/wear where the rim surrounds the stud. Not a huge issue if you replace your studs when a technician recommends, but for a couple of bucks you would spend now would save thirty to forty down the road... and more frequently.
  11. Oct 29, 2010 at 8:25 AM
    Fabulous
    Fabian
    Calgary, AB
    Indeed... I'm not sure what to get though, the plastic, or aluminum ones?! I read they the aluminum ones can sieze on to your hub. Almost every site I go to recommends the plastic ones, but plastic doesn't sound very strong, or am I just crazy?!
  12. Oct 29, 2010 at 6:23 PM
    GAmtber23
    Georgia
    I work at a tire shop.. we stock plastic ones, but I haven't noticed an issue with either. The only reason they would seize would be because of rust build up. Whenever the wheel is off the shop you go to should be brushing the hubs and would brush the ring as well. So as long as they do that I say go with whatever your more comfortable with. I personally would go with the aluminum as well. No real reason proof behind it I just agree that plastic sounds sketchy hah. Best of luck to ya
