Hub centering rings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 6taco, Jul 22, 2009.
  1. Jul 22, 2009 at 8:45 PM
    6taco
    6taco [OP] Active Member
    Florida
    06 taco 4x4 DC 2'' lift, MB Razors, 32s, tint
    lift, wheels, tires, bull bar, off road lights, tonneau cover, tint, system, interior lights
    I just had my wheels balanced at my local dealership. They told me that since I had aftermarket wheels there is a little space in between the hub of the wheel and the hub on the axle. They also told me the truck would ride smoother with hub centering rings and that I could get them from my local 4x4 shop. If someone could tell me if this is bs or where I could find them.
  2. Jul 22, 2009 at 9:05 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    BS..... Aftermarket wheels act just like stock wheels... tighten down the lugs and it should be flush. No gap between the wheel and the axle
  3. Jul 22, 2009 at 9:21 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    You don't know the size of his hub. I run rings with my American racing wheels.
  4. Jul 22, 2009 at 9:23 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    X2
    It all depends of the wheel hub bore.
  5. Jul 22, 2009 at 11:57 PM
    sincitytaco
    Las Vegas
    They definately can't hurt.
  6. Jul 23, 2009 at 12:41 AM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    Its definitely better to be hub centric, then all the weight resting on the lugs.
  7. Jul 23, 2009 at 9:47 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    I don't run hubcentric rings on my tacoma with AR Chamber wheels and have no issues, I would drive it the way it is for a while and if you notice any weird vibrations then look into the rings.
  8. Jul 23, 2009 at 9:51 AM
    TXRoper
    TXRoper Texas Edition
    Dean
    Plano, TX
    Texas Edition PreRunner SR5 - Super White
    2nd gen hub bore is 106mm (inside diameter)...but you need to know the outside diameter (hole size of your wheel), most aftermarket wheels for our trucks are 108mm. I ordered some Gorilla brand from Summit Racing...not delivered yet. Froogle.com search "hub ring". There are metal and polymer (plastic) types. I just figured to be safe, since wheels are not cheap.
  9. Jul 23, 2009 at 10:54 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    The rings would not fit with my Helo HE835 wheels.
  10. Jul 29, 2009 at 8:13 PM
    6taco
    Florida
    I have mb razor wheels
  11. Jul 30, 2009 at 6:57 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    Aftermarket wheels are going to have a different centerbore diameter than the spindle/axle hub. Rings are made to fill this gap, and restore hub-centric fit like the factory wheels.
    You'll need to know the wheel centerbore and spindle/axle centerbore sizes, and get rings to match. They're inexpensive.
    If you aren't having vibration issues right now, then you can decide whether or not to bother.
    The vehicle's hub diameter is different between 2wd and 4wd - and possibly different between different years and models of 4wd. I wouldn't take a dimension you read for granted. Call a good wheel shop and see if they have a selection on hand they can match you up with what you need.
  12. Aug 4, 2009 at 8:28 PM
    6taco
    Florida
    I have a local 4x4 shop that customizes all kinds of trucks. Maybe I will get with them on helping me fit some rings on my wheels.
  13. Aug 6, 2009 at 9:29 PM
    gcwaterski
    gcwaterski Well-Known Member
    will you post pics of them on ur truck? i like those.
