hub centric and lug centric spacers on same vehicle?
Discussion in 'Wheels & Tires' started by 98tacoma3rz, Aug 24, 2014.
  1. Aug 24, 2014 at 5:27 AM
    98tacoma3rz
    98tacoma3rz [OP] Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I have a 98 tacoma with manual locking hubs. I understand I need lug centric wheel spacers for the front. Do I get hub centric spacers for the rear then? Also what size should I get? 1.25 or 1.5? I have stock 15x7 alloys with 32x11.5 tires. They rub slightly in the front at full turn right now.
  2. Aug 24, 2014 at 5:35 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    My understanding is that you need hub centric both front and back. There are acorn style lug nuts that also help to center the lugs, but the hub centric is more important.
  3. Aug 24, 2014 at 5:44 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Everywhere that i've read online says that hub centric spacers will not work with manual locking hubs...
    970btu likes this.
  4. Aug 24, 2014 at 5:47 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Also, I have the stock alloy wheels which are hub centric...but wont work with hub centric spacers because I have manul hubs? Why are things so difficult lol
  5. Aug 25, 2014 at 4:03 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Your above assumption is correct. Get lug centric spacers for the front so they'll slide all the way through on your front hub. For the rear, get hub centric ones so you'll have a little lip for the wheel to snugly mount on.
    For size, just decide if you want your current wheels to stick out another 1.25" or 1.5".
