Hub Centric Rings - Worked! and Info
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XPOTRPR, Jun 27, 2013.
  1. Sep 8, 2013 at 10:31 PM
    #41
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    Subd, nice write up!
  2. Sep 17, 2013 at 3:53 AM
    #42
    JRFugitt
    Justin
    Texas
    '13 PreRunner V6
    They are hub centric. I tried the 106-108 rings on mine and they wouldn't fit. The wheels are tight but not like a factory steel wheel fit. How the lug nuts go on is real important. A proper road force balance helps as well.
  3. Oct 25, 2013 at 9:38 AM
    #43
    tractng
    tractng Well-Known Member
    I got new rims installed yesterday and noticed a vibration of the steering wheel on the freeway at 65-70 mph. DT balanced the tires but I installed it myself at home. I dealt with many aftermarket rims myself before.
    I bought the hub rings but didn't use it since the ZX wheel has cap that is used to center the wheel. Also, I have the correct nuts (conical style)
    Any recommendations? I will check the tire pressure after work and maybe ditch the cap and use the rings to see if the issue is still there. What is the ideal psi for 265/65/17? I had 245 before @30-32psi.
  4. Oct 25, 2013 at 9:48 AM
    #44
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    My first step would be to drive back to the discount tire and have them double check the balance and try again. mistakes happen.
  5. Apr 2, 2016 at 7:55 AM
    #45
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The TSS model is a dealer created model with aftermarket parts so in it is entirely possible that he may not have hub centric wheels.
  6. Apr 2, 2016 at 1:18 PM
    #46
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    I've been running a set of 235-85-16's DuraTracs for a couple years now, on three different sets of rims. Something about them is always off on the balance, had them on stock rims, and even RoadForce balanced and they never seem right. I'm going to finally burn them up at around 50K and be done with them.
  7. Jul 19, 2018 at 10:24 AM
    #47
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    #dumbquestion
    Do first gens and second gens have the same hub size (106mm)?
  8. Sep 10, 2018 at 4:32 PM
    #48
    Silentwolf
    Silentwolf Well-Known Member
    2017 Tacoma SR
    Cruise Control,Led Reverse lights, Weathertech mudflaps, Weathertech headlight protectors,Lund stepbar, Interior Leds, AVS Hoodflector, AVS In-Channel Ventvisor, aFe Pro DRY S airfilter, K & N cabin airfilter, A/C drain valve, Mostplus Led Headlights
    Same problem new wheels and tires rebalanced same shake 50-on up. DT never mentioned about hubcentric rings. Had to do all this research myself. Eaiting on them to come in. If these dont fix it im putting the new tires on my stock steelies and making them refund me for the wheels and new sensors
