Hub Centric Wheels?
Discussion in 'Wheels & Tires' started by Krazie Sj, Dec 24, 2009.
  1. Dec 24, 2009 at 10:15 PM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I was looking at ProComps website for the 1069 wheels, and they have the option for Hub Centric wheels and not. (I'm presuming Lug centric)
    Does this matter? What difference does that make for the wheel? Or is it just how it gets balanced with the tire at the shop?
    Any recommendations?
  2. Dec 24, 2009 at 10:17 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    you want lug centric. NOT hub centric
  3. Dec 24, 2009 at 10:26 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Yeah get the lug centric for your truck. It is confusing as hell. Our stock rims are Hub centric but not many companies make the correct hub size for our trucks, apparently its special. So if you want it to match the hubs you need to buy a 2mm hub spacer. I didn't go that route just tighten your lugs using a Cris cross pattern.
    Our stock hubs are 106mm but most aftermarket rims are 108mm and much smaller like 96 or 97. I learned this the hard way thanks to 4wheelparts not actually verifiying their hub size, instead they just agreed with me. I still have hard feelings about that deal.
  4. Dec 24, 2009 at 10:38 PM
    dylandercole
    Dylan
    yea 4wheel parts sucks. a couple bad deals weith them myself
  5. Dec 25, 2009 at 12:43 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Interesting. Thanks for the info!
