Hub centric
Discussion in 'Wheels & Tires' started by Rjwz28, Jul 2, 2019.
  1. Jul 2, 2019 at 11:08 PM
    Rjwz28
    Rjwz28 [OP] Well-Known Member
    Rob
    Big Island of Hawai’i
    2019 TRD sport
    Mostly stock. Icon wheels, running boards, sounds, custom grill, front camera.
    Do I need to find wheels with a certain bore to fit on my 2019 Trd sport. Are they supposed to be hub centric?
    Thanks!
  2. Jul 2, 2019 at 11:13 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    yes. hub centric. 6 x 139.7
  3. Jul 2, 2019 at 11:22 PM
    Rjwz28
    Rob
    2019 TRD sport
    So do I need a minimum hub size on the wheels I am purchasing? If so what is it?
  4. Jul 2, 2019 at 11:26 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    106.1mm
  5. Jul 2, 2019 at 11:28 PM
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
  6. Jul 2, 2019 at 11:28 PM
    Rjwz28
    Rob
    2019 TRD sport
    So, any wheel that I get needs to have a hub size of at least 106.1 mm?
  7. Jul 2, 2019 at 11:31 PM
    BVita
    BVita Mall Cruiser
    It doesn’t NEED to be hubcentric.
    My Volks have a center bore of 112mm. I don’t have an issue at all with anything.
    Quality and proper lug nuts center the wheel..
  8. Jul 3, 2019 at 7:39 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    As mentioned you can get wheels with a larger center bore than 106.1 mm. In the case that the center bore is larger than your stock hub the lugs make it lug centric or you can install hub rings to help center the wheel.
    Please let us know if we can help you choose wheels for your Tacoma.
