Hub conversion kit 1st Gen to 4th Gen Wheel
Discussion in '1st Gen. Tacomas (1995-2004)' started by Monroe Tacoma User, Jun 8, 2024.
  1. Jun 8, 2024 at 4:56 PM
    Monroe Tacoma User
    Monroe Tacoma User [OP] New Member
    R
    1996 4x4 V6 Tacoma
    Is there a hub conversion kit for 1st Gen to accept 4th Gen Wheel
  2. Jun 8, 2024 at 5:09 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^4th gen OEM wheels are +50mm offset with 95mm center bore. You will need something like 2" non-hubcentric wheel spacers to clear 1st gen suspension. The wheel spacers also need M14 studs as the lug holes on the wheels are sized for larger M14 lugnut shank dia. Existing M12 Tacoma lugnuts will wallow around in the holes. Something like this should work: https://www.amazon.com/dp/B01MTXW0HG/
    In addition you will need:
    M12 conical seat open lugnuts to bolt the spacers to the Tacoma.
    2022+ Tundra or 4th gen Tacoma M14 lugnuts to bolt the wheels to the spacers.
  3. Jun 9, 2024 at 6:59 AM
    Monroe Tacoma User
    R
    1996 4x4 V6 Tacoma
  4. Feb 9, 2025 at 3:24 PM
    u764385
    u764385 New Member
    2003 Toyota tacoma
    Did this ever work?
    I have the same issue at the moment.
