Hub sentric wheel help
Discussion in 'Wheels & Tires' started by Redgrom, Mar 10, 2012.
  1. Mar 10, 2012 at 4:05 PM
    Redgrom
    Redgrom [OP] http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Found tons of info on back spacing with a few searches but wanted to know how many run hub syntric wheels? My current set is lug syntric and take a good tech to Ballance. Thinking of moving down to 16's or 17' in the near future and don't really trust the guys at 4 wheel parts. Anyone have any recomendations? Looking to run roughly a 33x12.5
    Thanks.
  2. Mar 11, 2012 at 8:19 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Most wheels out there are lug-centric since a lot of them are made one size fit all type of deal. TRD wheels are hub-centric.
  3. Mar 11, 2012 at 8:29 PM
    koch1024
    koch1024 Well-Known Member
    Andy
    NYC
    04 Xtra Cab 3.4 5spd
    Icon 2.5s with Camburg UCA's, 5100s in the rear, K&N intake, Borla cat back,
    Most OEM wheels are hub centric and aftermarket wheels are lug centric. Hub centric is better for strength and balance. You can get hub rings that fit the gap between the hub and the bore of a lug centric wheel to essentially make it hub centric.
  4. Mar 12, 2012 at 11:15 AM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    I have a set of 17" procomp 7033's that cause some vibe(steering wheel wobble) at higher speeds. I just ordered a set of hub centric rings from discount tire today to fix the problem. I believe the hub bore on our 2nd gens is 106mm and the procomps are 108mm so the the rings should tighten things up nicely. I'll let you know by next week.
  5. Mar 12, 2012 at 11:18 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Mar 12, 2012 at 6:12 PM
    Redgrom
    Brent
    san clemente
    Thanks for the reply, that's the issue I am having now. Also the fact that I'm running dura tracks doesn't help much. Really love the tires off road but think I might switch back to at bfg's when I switch to a smaller rim. But think I might miss the dura tracks the few times I drive in the snow or on rocky trails.
  7. Mar 13, 2012 at 8:25 AM
    Koby
    Vancouver
    06 access trd
    I'm running the duratracs as well and I know what you mean. People say they are a quiet tire but they are only 'quiet' compared to a MT. Ha. But I do love them.
  8. Mar 30, 2012 at 7:26 PM
    Koby
    Vancouver
    06 access trd
    Have the rings in now and it definately helps. Gonna hit the highway tomorrow and see if the vibe comes back at all.
  9. Mar 30, 2012 at 9:17 PM
    Redgrom
    Brent
    san clemente
    Thanks for the reply! Look forward to hearing highway results.
  10. Apr 2, 2012 at 7:22 AM
    Koby
    Vancouver
    06 access trd
    Well, it's not perfect but it's a hell of a lot better. What ever the issue is, the rings dampen the vibes considerably. If you have an issue of just not being able to perfectly center your wheels (lug centric), then I believe this is a perfect fix. I may have some other issue but it still helped. You could easily right off whatever vibes I feel as 'tire noise'.
  11. Apr 2, 2012 at 7:24 AM
    Koby
    Vancouver
    06 access trd
    Oh yeah, one more thing, the guys at Discount Tire in Bellingham did not charge me thing for the rings(plastic) or their time! Unbelievable customer service!
  12. Apr 2, 2012 at 10:18 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    extended thread lug nuts, which have a shank at the end of them, help to better center the wheel on lug-centric setups. [​IMG]
