Hub To Power Accessories
Discussion in 'Technical Chat' started by HelloMyNameIs, Dec 16, 2018.
  1. Dec 16, 2018 at 6:06 AM
    HelloMyNameIs
    HelloMyNameIs [OP] I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    I’m looking for a solution to power accessories like light bars that is a hub connected to the battery by heavy gauge wire, so instead of running wires to my battery terminals I run them to this hub. I am pretty sure I’ve seen setups like this but have no idea what it’s called or how to search for it. Can anyone point me in a certain direction? Essentially I am anal about clean wiring and want a solution other than running everything to the battery posts. Thanks in advance!
  2. Dec 16, 2018 at 9:51 AM
    HelloMyNameIs
    Fuse block is what I think I’m looking for.
  3. Dec 16, 2018 at 12:01 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Fuse block, like the ever-popular Blue Seas offerings
    Or if you're not highly electrically inclined, opt for something like a SwitchPros 9100 and one of @mesojdm custom switch panels to mount it in
    Heck, even if you are very electrically inclined, maybe still opt for that.
    MESO likes this.
  4. Dec 17, 2018 at 12:23 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    quite a few different ways you can go depending on just what you want and your budget.
    figure how many loads your going to need when every thing is included .
    will you need relays for some or all loads plus the control ??
    will you build your own switch panel or buy a ready made one??
    just where your going to install this .Engine Bay or inside the cab
    This will help narrow down what you need
