Hubcentric or Not??
Discussion in 'Wheels & Tires' started by bigswoleone, Apr 30, 2012.
  1. Apr 30, 2012 at 8:04 PM
    bigswoleone
    bigswoleone [OP] Well-Known Member
    Craig
    Birmingham, AL
    11 DC PreRunner TRD Sport
    Alpine CDA-117 HU DLS Ultimate UP6i 6.5" comps Polk 6.5" coaxial rear-fill Polk MM series 10" sub Kicker ZX700.5 amp
    I'm getting ready to order some new wheels. I understand the whole backspacing aspect of it, however the wheels I'm looking at come in hubcentric or lugcentric. Which ones do I need??? 2011 DC PreRunner OME 885x.
    I searched and found that you can run lugcentric wheels with an adapter?? Well if I get the hubcentric version would it make everything easier (i.e. no adapter)?
  2. Apr 30, 2012 at 8:52 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
    always buy hubcentric wheels whenever you can. the tacoma hub bore is 106mm for your reference.
  3. Apr 30, 2012 at 9:09 PM
    bigswoleone
    Craig
    Birmingham, AL
    The sticky named "wheel specs" says that the hub bore is 108mm for the TRD Sport Alloy Wheels - 17" and obviously they fit...I don't understand.
  4. Apr 30, 2012 at 9:10 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    You need hubcentric wheels...
  5. Apr 30, 2012 at 11:13 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    most aftermarket wheel companies out there make "universal" lugcentric wheels and the hub opening is usually 108mm. this number has been floating around the internet and is misleading some folks. they buy the wheels, mount them on and think that the tacoma's hub bore is 108mm.
  6. May 3, 2012 at 11:57 AM
    JdMeF9SiR2
    JdMeF9SiR2 PARTS HOARDER
    Riverside CA
    06 Tacoma
    You can just buy the wheel you like and use a hub centric ring if you find that you have vibrations. You can purchase 108mm - 106mm hub centric rings very inexpensively.
    Personally, I have not had an issue with my Tacoma and 108mm center bore wheels and no hub rings.
    Also if the wheels you are purchasing have a push-thru cap, you won't need hub centric rings, and the cap will most likely be 2mm thick, which will center the 108mm center bore wheel on your hub.
  7. May 4, 2012 at 4:06 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Almost all aftermarket wheels are lug centric, so you don't need hubcentric.
    Hub centric wheels will have less of a chance of vibes, but that's about it.
  8. May 4, 2012 at 4:39 PM
    bigswoleone
    Craig
    Birmingham, AL
    Thanks for the responses TW!
  9. May 4, 2012 at 4:49 PM
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Very true, most aftermarket wheels are lugcentric. Given the choice, always go for hubcentric. What's the number one issue/problem have once people get new wheels? More often than not it's a vibration problems right after a new wheel/tire setup. Either it wasn't balanced correctly or mounted on properly and this is usually related to lugcentric setups.
    It's like buying wheel adapters/spacers that a lot us off-roaders use, you buy hubcentric when you can. Less possible issues equals less potential headaches.
  10. May 4, 2012 at 8:57 PM
    KPT
    09 Prerunner
    X1000
