Huge amount of water for 3.5 Tailpipe? Is this normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jboudreaux1965, Mar 25, 2024.
  1. Mar 26, 2024 at 2:11 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well I don't know about your truck but basically what comes out of every one else's tail pipe when it's running is H2O and CO2 the cat cleaned up most of the other stuff (water and carbon dioxide is what was left)
  2. Mar 26, 2024 at 2:26 PM
    jboudreaux1965
    jboudreaux1965 [OP] Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    I understand that, but that just seemed yto be extremely excessive amounts to me. maybe its just these engines...
  3. Mar 26, 2024 at 2:37 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Perfectly normal for any idling vehicle.
    BC Hunter likes this.
  4. Mar 26, 2024 at 4:14 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Nope. You should see how much condensate a 90%+ condensing furnace makes. [2 heat exchangers so the secondary one one strips so much heat from the exhaust/combusted gas that the water or condensate ''falls out'' of the combusted fuel and requires draining. It is slightly acidic so plastic is used as any steel [or brass/copper/bronze] would be eaten away by the slightly corrosive liquid.
    Steves104x4 likes this.
  5. Mar 26, 2024 at 5:04 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    All of the above advice is good and correct. This is absolutely nothing to worry about.
    Based on your pictures, you have a low spot between your muffler and exhaust tip. This spot - plus the muffler itself - will absolutely accumulate water vapor as it cools (condenses) before it exits the tail pipe. You might try loosening your clamps, adjust tilt angles, and see if you can eliminate that low spot. You could also drill a 1/4" weep hole..
    Remember also: these trucks also have a predominant forward rake. So even on level ground, water vapor in the exhaust is always trying to flow "uphill".
    While a proverbial sledgehammer cure to a small stationary insect, leveling and/or lifting the truck will eventually help.
    Do not discount or disregard the direction and inclination of the places you park. It is still fairly early to be watering your lawn every day, but do not overlook the obvious such as your neighbor's sprinkler giving that part of your truck a shower every day.
  6. Mar 26, 2024 at 7:36 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Sounds like time for a part out or trade to me. Or you could use this on startup :bucket:
  7. Mar 26, 2024 at 8:49 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    OP must be using this on his Taco
    petethemeat and BC Hunter like this.
