Huge gas milage issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Britts05tacoma, Nov 13, 2019.
  1. Nov 13, 2019 at 12:26 PM
    Britts05tacoma
    Britts05tacoma [OP] Well-Known Member
    Britton
    2005 tacoma trd prerunner blue
    bilstien ome 3 inch lift with dakar hd in the rear and spc ucas kc 50 inch on top c4 fab hybrid front bumper with baja designs fog lights
    Hey guys ive run into a wall i recently dropped gas milage from 320 a tank to like 280 i have no idea whats going on. The only changes ive made is i put new brakes in but their not grinding or rubbing. I just installed 3° rear axle shims in the rear and i put a afe pro dry air filter in.
    My truck is a 2005 1grfe with 120000 on the dash. Im running a 3 inch lift bilstien 5100s with ome 887s in the front and hd dakars in the rear no bumpers or added weight tho.
    I tried running seafoam thru the tank and doing a seafoam intake clean to no avail. I dont have any engine lights on and toyota said they couldnt help me.
    Any help is appriciated
  2. Nov 13, 2019 at 12:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    40 miles per tank is significant, but not totally unheard of for everything being in good condition. Have you been speeding at all recently? Any recent changes in driving habits? It's all relevant to a potential drop.
    b_r_o likes this.
  3. Nov 13, 2019 at 12:38 PM
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Charlotte, NC
    22 Tremor 402A, 22 T4R ORP
    Winter Gas?
  4. Nov 13, 2019 at 12:38 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Winter blend gas?
  5. Nov 13, 2019 at 12:45 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Go south my friend .
    Edit --- that's what she said :) .
  6. Nov 13, 2019 at 12:54 PM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    By any chance was it the rear brakes? Could be that they were over tightened and now the truck is fighting the resistance from them.
  7. Nov 13, 2019 at 12:58 PM
    VTacoma6
    VTacoma6 Well-Known Member
    Vince
    Florida
    2015 Toyota Tacoma Trd Sport 4x4
    16 inch Matte Bronze FN Countersteer Type X wheels 0 offset With Goodyear Duratracs 265/75R16
    I’ve been tracking my gas mileage and seem to get better gas mileage in the city Vs highway. I get 17 city and 14.5 highway. I’m clueless. I have 265/75/16 everything else is stock. Something seems off. I have cleaned my throttle body and changed my k&n filter back to OEM.
  8. Nov 13, 2019 at 1:30 PM
    Britts05tacoma
    Britton
    No significant change in driving
  9. Nov 13, 2019 at 1:30 PM
    Britts05tacoma
    Britton
    It was front brakes
  10. Nov 13, 2019 at 1:31 PM
    Britts05tacoma
    Britton
    I was under the impression that winter gas wasnt really different from summer gas any more
  11. Nov 13, 2019 at 1:54 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I’ve also lost about 2 mpg lately but I attribute that to the new LT winter tires I just put on....not sure if that was a good idea in hindsight.
  12. Nov 13, 2019 at 2:18 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Winter blend gas !
  13. Nov 13, 2019 at 2:28 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Miles/tank is useless information. When you calculate miles/gallon then we have useful information.
    ASSUMING that you filled up and put in EXACTLY 20 gallons each time you only dropped from 16 mpg to 14 mpg. That isn't a huge difference and about right when changing to winter fuel. And trying to judge fuel mileage going on miles/ tank is extremely inaccurate. Even when you think the tank is empty the amount of gas you put in could vary 2-3 gallons each time
    I've seen a greater difference than that by driving into a steady wind vs with the wind at my back on the return trip. A slight difference in air pressure in your tires will account for more than 2 mpg, and with cold weather coming on your air pressure will naturally be less in your tires. Check them, they probably need more air.
  14. Nov 13, 2019 at 2:32 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    That’s only 2 mpg roughly. It’s probably winter gas. Happens to us all
    Britts05tacoma[OP] likes this.
  15. Nov 13, 2019 at 4:16 PM
    racerX969
    racerX969 Active Member
    Best mpg I ever had was 21 in 4wd doing 45 to 50 mph in a blizzard with a tailwind.
  16. Nov 13, 2019 at 6:14 PM
    Britts05tacoma
    Britton
    Yea i guess man. I dont remember it being bad last year but i didnt have the lift last year either
  17. Nov 13, 2019 at 6:25 PM
    JC15Taco
    JC15Taco Well-Known Member
    Jeff
    SK, Canada
    '15 TRD DCLB
    Gentlemen... nothing to do with "winter" gas....it's just winter. From the frozen mid-continent here...my mileage drops 20% when the weather goes south.
    Fluids get stiff, grease gets stiff... everything gets stiff (except meo_O). Burns fuel like crazy.
  18. Nov 13, 2019 at 6:48 PM
    Britts05tacoma
    Britton
    Damn wwll i appriciate all the help its good to know nothing is wrong
  19. Nov 13, 2019 at 6:49 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    I agree miles per tank is useless information. MPG will give you a more accurate idea of what’s going on.
  20. Nov 13, 2019 at 6:58 PM
    QuicksandTaco
    Cody
    Oregon
    Technically winter blend gasoline has higher RVP and less energy than summer blend which is the reason for lower fuel economy.
    We have smart phones at the top of the fingers, might as well use it!
