Huge Gas Mileage Increase -ATF Flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MPBFlorida, Mar 23, 2022.
  1. Mar 23, 2022 at 1:44 PM
    MPBFlorida
    MPBFlorida [OP] New Member
    2014 Taco Sport
    Guys, I'm not mechanic, but have to share this ... Even though it makes no sense to me. My Taco was bought new and currently has 110k miles. I have done some moderate towing. When new, I might have seen 20mpg on the highway .. OCCASIONALLY. Over the years,MPG dropped to 16.5 to max of 17. I have done all maintenance regiously. Although I had the ATF pan drained ... Never did a flush. There were so many threads saying not so do that. Well, 2 weeks ago, I had Jiffy Lube flush the ATF. Gas mileage has leaped to over 20 MPG ... on the engine monitoring system, I register 21.5 on the highway. Easily 4 MPG better. So, I cannot believe the ATF flush could make this much a difference ... but it is the only variable. Just thought I would share this experience. I has been a welcome change at $3.90 + per gallon.
    wi_taco and Lenny Dykstradamus like this.
  2. Mar 23, 2022 at 1:46 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Could be related to a fluid with lower viscosity than the stock fluid, or possible they increased the psi in your tires while it was there?
    Gunshot-6A and RedWings44 like this.
  3. Mar 23, 2022 at 2:04 PM
    eon_blue
    Azusa, CA
    I can't believe you let Jiffy Lube touch your Tacoma
  4. Mar 23, 2022 at 2:19 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This gives me some hope that there's a chance I can get some mpg back. My truck is TERRIBLE. I was just starting to plan out a bunch of maintenance that I wanted to do soon and a trans service was on the list but I hadn't planned on the flush since I can't do that myself. I'm rethinking that now...
  5. Mar 23, 2022 at 2:24 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I would never let jiffy lube touch my truck even for a oil change. My truck is awful on fuel thats why I got a 4 banger older civic now for a daily.
  6. Mar 23, 2022 at 2:25 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Coincidence, and possibly winter fuel being phased out. Check it manually and get back to us in 2-3 months. A tank or 2 is easily an anomaly. The ATF service had nothing to do with it.
    vtown, Gunshot-6A and Fullboogie like this.
  7. Mar 23, 2022 at 2:32 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Maybe your atf level was off and not shifting proper now you are at the correct level...:notsure:
    But I agree with coincidence for now.
    Edit: jiffy lube :(
    Don't trust your truck to them.
    mallege, Goldwrench and DGXR like this.
  8. Mar 23, 2022 at 4:28 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    You will be back at jiffy schlube when ur trans fucks up
    Good luck
    kgarrett11, mallege and Ricardo13x like this.
  9. Mar 24, 2022 at 10:47 AM
    vettaco
    vettaco Well-Known Member
    Vince
    09 AC PreRunner
    Actually wouldn't lower viscosity fluid translate to more slippage in the torque converter = lower mpgs?
  10. Mar 24, 2022 at 10:51 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    IDK what came out or what went in, but I know LV fluids are supposedly better on mpg. It would depend on a bunch of factors for the OP's specific application and driving conditions, but I'm thinking the fluid doesn't have much of anything to do with the mpg increase though unless it was actually syrup in there.
  11. Mar 24, 2022 at 2:29 PM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Changing the ATF should not impact fuel mileage.
    I had a Toyota dealer do an AT flush and they sprayed ATF all over the engine compartment. Never Jiffy Lube. What are you going to do?
  12. Mar 24, 2022 at 2:48 PM
    lynyrd3
    Bill
    East Central Upstate NY
    X2
  13. Mar 24, 2022 at 5:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Maybe they also cleaned the MAF and forgot to mention it
