HUGE TRD PRO suspension SCORE!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jaime.portillo, Feb 9, 2019.
  1. Feb 9, 2019 at 2:38 PM
    Jaime.portillo
    Jaime.portillo [OP] Well-Known Member
    Jaime
    Albuquerque, New Mexico
    2018 TRD OR
    Hello everyone! I’m needing a little of help & advice! Just purchased the TRD Pro Suspension yesterday! Two shocks up front & rear for $150! YES You read that right!
    My truck is a 2018 TRD OR DCSB!
    I do feel confident to swap it myself, but will take it to a shop for good measure. I have a few questions I hope some of you could answer. Or give me advice?
    Can the suspension just be swapped?
    Will I need longer break lines up front?
    Will stock control arms need to be or are they HIGHLY recommended to be replaced?
    I don’t do any crazy off roading, or crawling, just moderate trails!
    Will I need to purchase new hardware? Or will existing hardware be fine?
    & who has done it?
    Anything else I should know?
    Thank you all!
    I know picture below only shows front, but have rears as well!
  2. Feb 9, 2019 at 2:42 PM
    SpeySquatch
    2016 TRD OR DCSB
    Longer break lines not needed. All stock stuff should be fine. Those shocks don’t have much travel so you aren’t extending anything.
    I run extended shocks and the lines were just a smidge (and I mean stretching the line smidge) short at full droop
    ...how did you get those shocks so cheap? You weren’t by chance in a factory with all the workers dressed like Santa and his elves right?
    https://goo.gl/images/gWUtJq
    (If you’ve seen the movie it probably makes more sense - they make knock off toys)
  3. Feb 9, 2019 at 2:44 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Awesome!
    Shocks should swap right in. You could probably do it all yourself easy.
  4. Feb 9, 2019 at 2:46 PM
    Jaime.portillo
    Jaime
    2018 TRD OR
    Good deal, I figured just wanted to get some opinions before I took it to the shop
  5. Feb 9, 2019 at 2:47 PM
    19cement4xor
    19cement4xor Well-Known Member
    Eric
    Clear Lake TX
    19 Cement Trd off road 4x4
    TRD Pro suspension, Method Nv, 265/70-17 bfg ko2, meso TRD center caps
    Awesome deal , just did mine myself by unbolting uca ball joint & sway bar, easy and quick.
    Jaime.portillo[OP] likes this.
  6. Feb 9, 2019 at 2:48 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Direct swap, should be about a two beer job with how new and corrosion free the truck is.
  7. Feb 9, 2019 at 2:49 PM
    19cement4xor
    Eric
    Clear Lake TX
    Why and how so dam cheap , I paid 1400$ and was very happy with the price.
  8. Feb 9, 2019 at 2:53 PM
    19cement4xor
    Eric
    Clear Lake TX
    Caster camber was fine , mine needed a small toe adjustment.
  9. Feb 9, 2019 at 2:53 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Easy swap. The UCA's from the Pro are the same... only thing you'll need is the parking brake spacer for the passenger side.
    Edit:
    Did the swap myself. Let me know if you have any questions.
    Jaime.portillo[OP] and JoeCOVA like this.
  10. Feb 9, 2019 at 3:03 PM
    19cement4xor
    Eric
    Clear Lake TX
    I did not follow the directions I did not touch the LCA, just the UCA ball joint, sway bar. Super easy 4 hours total front and back with a few beer breaks for pics.
  11. Feb 9, 2019 at 3:05 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Having done it both ways... I agree, disconnecting the UCA from the spindle was much easier.
  12. Feb 9, 2019 at 4:10 PM
    Twotacojuan
    Twotacojuan Well-Known Member
    St. Cloud Fl
    2019 OR shortbed & 01 dc prerunner
    Where did you guys find the parts so cheap? Im close to many yards but everything is an arm and a leg around me.
  13. Feb 9, 2019 at 5:47 PM
    Jaime.portillo
    Jaime
    2018 TRD OR
    That’s how I felt for the longest, I saw a guy pull up to work in a TRD PRO & asked him if he had the OEM wheels and tires because that’s what I’m looking for, and he said no I sold the set for $400! Then he mentioned actually I have the PRO suspension and he said well I’ll take $150 for it! I said deal & he has ICON 6” with 35” so he had NO need for it it was just sitting there!
    synaps3 and su.b.rat like this.
  14. Feb 9, 2019 at 5:48 PM
    Jaime.portillo
    Jaime
    2018 TRD OR
    Thank you very much, might holler at you! How much of an improvement was the ride?
  15. Feb 9, 2019 at 5:50 PM
    su.b.rat
    su.b.rat broken truck
    pretty funny, right place and time i guess. enjoy it. it's a nice kit for basic stuff, rides nice.
  16. Feb 9, 2019 at 5:52 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    I have the rears installed. Luv them.
  17. Feb 9, 2019 at 7:15 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Pretty substantial. For $150... I don't think you'll find a better mod.
    19cement4xor likes this.
  18. Feb 11, 2019 at 9:38 PM
    19cement4xor
    Eric
    Clear Lake TX
    Handles much better , no brake dive and will actually corner now. More planted solid feel.
    Negatives for me are these soak up larger bumps but you will still feel smaller bumps. And once you stop if you roll forward and brake again you get a little bounce or rocking, hard to explain.
    I don’t regret doing it at all.
